I have an old Sony amplifier (TA-F117R) next to my desk where I keep my cell phone. Sometimes I put it ontop the amplifier, because it is pervecly alighed with the surface.
When I hang some call up and land the phone close to the amplifier the loud beeping noises started to burst from the speakers, something like the "modem calls" in the old ages of dial-up internet connection.
I suspect the phone - transmitter negotiation is responsible for that. The radi waves transmitted from the cell phone are strong enough to induce parasitic currents in the amplifiers circuits leading to the noise.
What makes me wonder is that this noise is generated only when I hang up the call and put the phone close the amp. I can send/recieve SMS, e-mails and browse the internet using the phone. I have bluetooth, NFC, GPS and Wi-Fi on all the time.
I have Sony Xperia L now, but I could observe the interference with all phones I used to have (Philips Fisio, SonyEricsson K770i, Samsung Galaxy-Y,...) and amplifiers (Old stereo, PC speakers).
What exactly causes such interferences and why SMS and others are transmitted without such interference.
The answer here blames the GSM protocol and the fact 800 - 900 MHz signal interfers with the amplifier's structures. However it dosn't address why SMS and data transfer do not cause such interference.
Crowley
  • 389
The usual problem with interference from GSM cell phones is caused by rectification of the strong RF signal at the semiconductor junctions at the input of the amplifier.
GSM uses Time Domain Multiplexing Access (TDMA) to share the RF frequency with other users - it only turns the RF signal on for a short time at a 217Hz rate synchronized with other users and the base station using the remaining time.
This short relatively high-power RF can be rectified by any semiconductor junctions to cause a slight change in the bias level of the amplifier for the duration of the RF pulse (~0.5ms). This is a buzz at 217Hz that can then get amplified by the amplifier to appear at the speakers.
It is not necessary for the amplifier to have any response at the RF frequency which can be up to about 2GHz.
The cure is to provide filtering to avoid the RF signal getting to the first stage of the amplifier. The filtering may be as simple as a small high-frequency capacitor across the inputs, an RF choke in series or a more complex filter.
Bipolar junction transistors are more sensitive to this effect than FET front ends so it will be affected by which devices are used.
It's not obvious why SMS and data transfers would not cause noise as well - they use the same mechanism for transferring data.
More recent cell-phone protocols used in 4G and 5G cellular networks don't use TDMA but OFDMA instead. The cell-phone transmitters are on constantly rather than being interrupted so the amplitude demodulation that occurs accidentally with GSM wouldn't result in an audio tone. It may result in other effects by affecting the biasing and is conceivable that there might be clicks, pops or hisses resulting.
Kevin White
  • 32,097
  • 47
  • 74
    Exactly, the other answers which don't mention the term "rectification" miss the point! This is your garden variety opamp (like 5532) doing RF detection... and they're quite good at it. – bobflux May 03 '17 at 23:20
    +1, to add: the rectification would also occur on any junction between different metal alloys as well, like on audio plugs, etc. – Ale..chenski May 04 '17 at 02:47
  • There's interference with data transfer as well, as soon as I turn it off it stops. – Milan Velebit Jun 17 '20 at 19:29
  • @KevinWhite I just happened to be reading this answer the moment you decided to edit it five years later :) I thought it was a glitch. – Sedat Kapanoglu Jan 24 '22 at 17:18
    @SedatKapanoglu - somebody had just voted on it and when I read it I thought it needed an edit here and there to make it clearer. – Kevin White Jan 24 '22 at 17:21
  • @KevinWhite yeah, that would be me. now it makes sense :) thank you for the answer. maybe it would be beneficial to add why it doesn't happen as much nowadays? – Sedat Kapanoglu Jan 24 '22 at 17:52
Even though audio amplifiers won't typically process any signals above 40kHz or so in usable fashion, the early stages of such amplifiers may not completely filter them out. If high-frequency signals are strong enough, they may overdrive an amplifier stage, causing distortion. Applying harmonic distortion to a signal that contains multiple frequencies may yield new spectral content at any frequency which can be formed by adding or subtracting any integer multiples of any frequencies present in the original.
Some wireless protocols use a variety of frequencies which are distributed in somewhat random fashion. If such transmissions are picked up by an audio amplifier, the sum and difference tones will be distributed over a wide range of frequencies, and the result will simply be a slight increase in the level of background noise.
The problem with GSM is that its spectral content is distributed in a way that causes many of the sum and difference frequencies to coincide, thus concentrating their energy at a few discrete audio frequencies. If the designers of GSM had foreseen the extent to which it would wreak havoc on audio, they could have easily adjusted the design slightly to avoid such frequency concentrations. Unfortunately, by the time the problem was discovered it would have been impractical to adjust the design.
supercat
  • 45,939
  • 84
  • 143
The chirps you hear from inactive speaker coils or amplifiers is the AM demodulation of Broadcast sync tones from cell phones exciting the coils.
This carrier burst sync to nearest towers is modulated quite different from the constant amplitude frequency hopping schemes used.
Even some car speakers nearby causes the coils to rub on the magnets from lateral forces of microwave energy on parasitic resonances tilting the coil while moving, which adds some sharper tones to pattern of "dit-da-da-dit" repeated several times.
