What is the power factor of a classical power supply ? I mean a transformer, rectifier and filter capacitor. Is it constant ?
Marus Gradinaru
  • 393
    This depends on the size of the decoupling capacitor and that one depends on the amount of ripple which is acceptable. – Janka May 02 '17 at 21:57
  • I measured a PF for a classical PSU and when loaded I read PF around 0.4...0.6 – G36 May 02 '17 at 22:07
There is no one answer. No, it is not constant.
Think about it. When there is no load on the output, the transformer primary just looks like a inductor. However, when there is a load there are current spike twice per line cycle when the rectifiers conduct. That adds a lot of harmonics, which contribute to a lower power factor.
Olin Lathrop
  • 310,974
  • 428
  • 915
When a bridge rectifier is used you get a very non-linear current taken from the AC supply because the diodes are only conducting for a small duration of the time: -
This can make the overall power factor very poor but it is load dependent and this means there is no one fixed value for power factor.
