I want to solve this exercise in the figure below.The question is "Recognise as many known Sub-circuits as you can in LM386 circuit".I tried it and found only that the transistor down and in the left hand is a current mirror and active load.Also the output looks like Class A amplifier.Can anyone help me to find other sub-circuits. enter image description here
elecV1
  • 374
    How about Szilaki pair, Darlington pair, differential pair with emitter degeneration. Class B output stage, Emitter follower. – Kevin White May 02 '17 at 21:20
    Try read this http://www.electrosmash.com/lm386-analysis But first you should study classical BJT op amp circuit. http://shop.emscdn.com/KitInstrux/741/741_principles_RevA104.pdf – G36 May 02 '17 at 21:40
    This also may be handy: https://www.ti.com/lit/an/snoa737/snoa737.pdf and from the same page http://www.electrosmash.com/jrc4558-analysis – G36 May 02 '17 at 21:51
    If you go to the bottom of my answer here, https://electronics.stackexchange.com/questions/281753/cant-understand-an-ab-amplifier-diagram/281838#281838 , you will find some discussion that may help you some. – jonk May 02 '17 at 22:12
    Oh. And I probably should have included this, as well: https://electronics.stackexchange.com/questions/273867/transfer-function-of-a-lm380-power-amp/273901#273901 Sorry about that. – jonk May 02 '17 at 22:28
  • Thank you so much jonk,G36, Kevin White I really appreciate your help. – elecV1 May 03 '17 at 06:57
We are not here to do your homework for you. If you really knew these sub-circuits, they would jump out at you.
However, look up things called differential pair, darlington, and cascode. You should not only just try to identify them, but study them to understand how they work in their own right. These can be useful building blocks when designing circuits, but more importantly, the concepts behind them are essential for designing a wide variety of circuits.
This is a worthwhile assignment, even if it appears to be just about silly naming conventions at first glance.
Olin Lathrop
  • 310,974
  • 428
  • 915
  • Mr Olin Lathrop thank you for being patient and helping me improve.I really appreciate your help. – elecV1 May 03 '17 at 07:04
