I’m working on a project that involves a STM32 MCU (on the STM32303C-EVAL board to be exact) that has to respond to an external interrupt. I want the reaction to the external interrupt to be as fast as possible. I have modified a standard peripheral library example from the ST web page and the current program simply toggles a LED at each successive rising edge on PE6:
#include "stm32f30x.h"
#include "stm32303c_eval.h"
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
static void EXTI9_5_Config(void);
int main(void)
  /* Initialize LEDs mounted on STM32303C-EVAL board */
  STM_EVAL_LEDInit(LED1);
  /* Configure PE6 in interrupt mode */
  EXTI9_5_Config();
  /* Infinite loop */
  while (1)
// Configure PE6 and PD5 in interrupt mode
  /* Enable clocks */
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOD | RCC_AHBPeriph_GPIOE, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  /* Configure input */
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  /* Connect EXTI6 Line to PE6 pin */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOE, EXTI_PinSource6);
  /* Configure Button EXTI line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line6;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set interrupt to the highest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
The interrupt handler looks like this:
void EXTI9_5_IRQHandler(void)
  if((EXTI_GetITStatus(EXTI_Line6) != RESET))
    /* Toggle LD1 */
    STM_EVAL_LEDToggle(LED1);
    /* Clear the EXTI line 6 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line6);
In this particular case, the interrupts are created by an external programmable function generator running at 100 Hz. After examining the MCU response on an oscilloscope, I was rather surprised that it takes nearly 1.32 us for the MCU to begin processing the interrupt: enter image description here
With the MCU running at 72 MHz (I’ve checked the SYSCLK output on the MCO pin beforehand) this amounts to nearly 89 clock cycles. Shouldn’t the MCU response to the interrupt be much faster?
P.S. The code was compiled with IAR Embedded Workbench and optimized for highest speed.
K.R.
  • 591
  • Are you sure that's the delay to start processing the interrupt? What happens when you remove the if condition and just toggle? – BeB00 Apr 25 '17 at 19:56
  • @BeB00 the `if{}` statement is needed because the interrupt routine does not know what the source of interrupt is. – Rohat Kılıç Apr 25 '17 at 19:59
  • If i remember correctly, the latency should be around 10-15 cycles – BeB00 Apr 25 '17 at 20:01
    Right, but what happens when you remove it in your experiment? I assume you dont have a load of other interrupts triggering this constantly, so you should be able to get a better feel for the actual delay – BeB00 Apr 25 '17 at 20:02
    It really shouldn't be a mystery. Look at the compiled assembler code for your interrupt function and refer to the appropriate ARM ref manual to add up the number of clock cycles for each instruction... – brhans Apr 25 '17 at 20:13
  • If I'm not mistaken, my interrupt function in the assembler code looks like this: `EXTI9_5_IRQHandler: PUSH {LR} CFI R14 Frame(CFA, -4) CFI CFA R13+4 SUB SP,SP,#+4 CFI CFA R13+8 MOVS R0,#+6 CFI FunCall EXTI_GetITStatus BL EXTI_GetITStatus CBZ.N R0,??EXTI9_5_IRQHandler_0 MOVS R0,#+0 CFI FunCall STM_EVAL_LEDToggle BL STM_EVAL_LEDToggle ADD SP,SP,#+4 CFI CFA R13+4 POP {LR} CFI R14 SameValue CFI CFA R13+0 MOVS R0,#+6 CFI FunCall EXTI_ClearITPendingBit B.W EXTI_ClearITPendingBit CFI CFA R13+8` – K.R. Apr 25 '17 at 21:21
Problem
Well you have to look at the functions you are using, you can't just make assumptions on the speed of code you haven't looked at:
This is the EXTI_GetITStatus function:
ITStatus EXTI_GetITStatus   (   uint32_t    EXTI_Line    )
  ITStatus bitstatus = RESET;
  uint32_t enablestatus = 0;
  /* Check the parameters */
  assert_param(IS_GET_EXTI_LINE(EXTI_Line));
  enablestatus =  *(__IO uint32_t *) (((uint32_t) &(EXTI->IMR)) + ((EXTI_Line) >> 5 ) * 0x20) & (uint32_t)(1 << (EXTI_Line & 0x1F));
  if ( (((*(__IO uint32_t *) (((uint32_t) &(EXTI->PR)) + (((EXTI_Line) >> 5 ) * 0x20) )) & (uint32_t)(1 << (EXTI_Line & 0x1F))) != (uint32_t)RESET) && (enablestatus != (uint32_t)RESET))
    bitstatus = SET;
  else
    bitstatus = RESET;
  return bitstatus;
As you can see, this is not a simple thing requiring just a cycle or two.
Next is your LED toggle function:
void STM_EVAL_LEDToggle (   Led_TypeDef     Led  )
  GPIO_PORT[Led]->ODR ^= GPIO_PIN[Led];
So here you have some array indexing and a read modify write to toggle the LED.
HALs often end up creating a good amount of overhead because they must take care of wrong settings and wrong usage of the functions. The needed parameter checking and also the translation from a simple parameter to a bit in the register can take a serious amount of computing (well for a time critical interrupt at least).
So in your case, you should implement your interrupt bare metal directly on the registers and not rely on any HAL.
Example solution
For example something like:
if (EXTI->PR & EXTI_PR_PR6)
    GPIOE->BSRR = GPIO_BSRR_BS_8;
    EXTI->PR = EXTI_PR_PR6;
Note: this will not toggle the LED but simply set it. There is no atomic toggle available on the STM GPIOs. I also don't like the if construct I used, but it generates faster assembly than my preferred if (EXTI_PR_PR6 == (EXTI->PR & EXTI_PR_PR6)).
A toggle variant could be something along these lines:
static bool LEDstate = false;
    if (!LEDstate)
        LEDstate = true;
    else
        GPIOE->BSRR = GPIO_BSRR_BR_8;
        LEDstate = false;
Using a variable residing in RAM instead of using the ODR register should be faster, especially when you use 72 MHz, because access to the peripherals can be slower due to synchronization between different clock domains and peripheral clocks simply running at a lower frequency. Of course, you may not change the state of the LED outside of the interrupt for the toggle to work correctly. Or the variable must be global (then you have to use the volatile keyword when declaring it) and you have to change it everywhere accordingly.
Also note, that I'm using C++, hence the bool and not some uint8_t type or similar to implement a flag. Although if speed is your primary concern you should probably opt for a uint32_t for the flag as this will always be aligned correctly and not generate additional code when accessing.
The simplification is possible because you hopefully know what you are doing and always keep it that way. If you really just have a single interrupt enabled for the EXTI9_5 handler you can get rid of the pending register check altogether, reducing the number of cycles even further.
This leads to another optimization potential: use a EXTI line which has a single interrupt like one of EXTI1 to EXTI4. There you don't have to perform a check whether the correct line has triggered your interrupt.
brhans
  • 14,373
  • 49
Arsenal
  • 17,464
  • 32
  • 59
    It's hard to tell from C code how much instructions it would take. I have seen bigger functions optimized to a couple of instructions which didn't even involve an actual call. – Dmitry Grigoryev Apr 26 '17 at 08:21
    @DmitryGrigoryev as register are declared as `volatile` the compiler is not allowed to optimize much in the functions above and if the functions are not implemented inline in the header, the call usually doesn't get optimized away either. – Arsenal Apr 26 '17 at 08:26
Following PeterJ's suggestion I've omitted the usage of SPL. The entirety of my code looks like this:
void EXTI0_IRQHandler(void)
    // I am simply toggling the pin within the interrupt, as I only want to check the response speed.
     GPIOE->BSRR |= GPIO_BSRR_BS_10;
     GPIOE->BRR |= GPIO_BRR_BR_10;
     EXTI->PR |= EXTI_PR_PR0;
int main()
    // Initialize the HSI:
    RCC->CR |= RCC_CR_HSION;
    while(!(RCC->CR&RCC_CR_HSIRDY));
    // PLL configuration:
    RCC->CFGR &= ~RCC_CFGR_PLLSRC;     // HSI / 2 selected as the PLL input clock.
    RCC->CFGR |= RCC_CFGR_PLLMULL16;   // HSI / 2 * 16 = 64 MHz
    RCC->CR |= RCC_CR_PLLON;          // Enable PLL
    while(!(RCC->CR&RCC_CR_PLLRDY));  // Wait until PLL is ready
    // Flash configuration:
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    FLASH->ACR |= FLASH_ACR_LATENCY_1;
    // Main clock output (MCO):
    RCC->AHBENR |= RCC_AHBENR_GPIOAEN;
    GPIOA->MODER |= GPIO_MODER_MODER8_1;
    GPIOA->OTYPER &= ~GPIO_OTYPER_OT_8;
    GPIOA->PUPDR &= ~GPIO_PUPDR_PUPDR8;
    GPIOA->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR8;
    GPIOA->AFR[0] &= ~GPIO_AFRL_AFRL0;
    // Output on the MCO pin:
    RCC->CFGR |= RCC_CFGR_MCO_SYSCLK;
    // PLL as the system clock
    RCC->CFGR &= ~RCC_CFGR_SW;    // Clear the SW bits
    RCC->CFGR |= RCC_CFGR_SW_PLL; //Select PLL as the system clock
    while ((RCC->CFGR & RCC_CFGR_SWS_PLL) != RCC_CFGR_SWS_PLL); //Wait until PLL is used
    // LED output:
    RCC->AHBENR |= RCC_AHBENR_GPIOEEN;
    GPIOE->MODER |= GPIO_MODER_MODER10_0;
    GPIOE->OTYPER &= ~GPIO_OTYPER_OT_10;
    GPIOE->PUPDR &= ~GPIO_PUPDR_PUPDR10;
    GPIOE->OSPEEDR |= GPIO_OSPEEDER_OSPEEDR10;
    // Interrupt on PA0:
    GPIOA->MODER &= ~(GPIO_MODER_MODER0);
    GPIOA->OSPEEDR |= (GPIO_OSPEEDER_OSPEEDR0);
    GPIOA->PUPDR &= ~(GPIO_PUPDR_PUPDR0);
    SYSCFG->EXTICR[0] &= SYSCFG_EXTICR1_EXTI0_PA;
    EXTI->RTSR = EXTI_RTSR_TR0;
    EXTI->IMR = EXTI_IMR_MR0;
    NVIC_SetPriority(EXTI0_IRQn, 1);
    NVIC_EnableIRQ(EXTI0_IRQn);
    while(1)
and the assembly instruction look like this:
EXTI0_IRQHandler:
        LDR.N    R0,??DataTable1  ;; 0x48001018
        LDR      R1,[R0, #+0]
        ORR      R1,R1,#0x400
        STR      R1,[R0, #+0]
        LDRH     R2,[R0, #+16]
        ORR      R2,R2,#0x400
        STRH     R2,[R0, #+16]
        LDR.N    R0,??DataTable1_1  ;; 0x40010414
        LDR      R1,[R0, #+0]
        ORR      R1,R1,#0x1
        STR      R1,[R0, #+0]
        BX       LR               ;; return
This improves matters quite a bit, as I've managed to get a response in ~440 ns @ 64 MHz (i.e., 28 clock cycles).
K.R.
  • 591
    Change your `BRR |= ` and `BSRR |= ` to just `BRR = ` and `BSRR = `, those registers are write only, your code is reading them, `ORR`ing the value and then writing. that could be optimized to a single `STR` instruction. – Colin Apr 26 '17 at 11:41
  • Move your EXTI handler & vectors to CCMRAM – 0___________ Apr 26 '17 at 17:08
There are some errors in your code = BSRR register is write only. Do not use |= operator, just simple "=". It will set /reset the proper pins. Zeroes are ignored.
It will save you couple of clocks. Another hint: move your vector table & interrupt routines to CCMRAM. You will save some another ticks (flash waitstates etc)
PS I cant comment as I do not have enough reputation :)
0___________
  • 2,458
The answer is extremely easy: great HAL (or SPL) library. If you do something time sensitive use bare peripheral registers instead. Then you will get the correct latency. I cant understand what is the point to use this ridiculous library to toggle the pin!! or to check statue register.
0___________
  • 2,458
