The question I need to solve is: how do the h parameters (hybrid) vary as a function of frequency?
In particular, I need to estimate the Y parameters (admitance parameters) for a 2N3904 transistor, but I only have the h parameters, as a function of the collector current, measured with a 1 kHz signal.
I need the Y parameters to model a circuit with this transistor, which operates at 10 Mhz. Is it possible to estimate the Y parameters @ 10 Mhz, from the h parameters @ 1 kHz?
I know that it is possible to convert from h parameters to Y parameters, but I don't know how the frequency variation affects it.
An alternative is to find a datasheet where the admittance parameters are specified for a range of frequencies, but I have searched without result.
ocrdu
  • 8,705
  • 30
  • 42
Martin Petrei
  • 3,034
Z, Y, H, S parameters are "measured" values at a specific bias and frequency.
You can convert H to Y but the bias and frequency is the same.
So 1Khz H can only be converted to 1Khz Y.
