One diode will be enough for flyback protection provided it is rated for the full current.
However, I am concerned that your circuit may not be designed to handle the initial in-rush current of those motors. The circuit needs to be designed to handle that current not the rated running current.
Also, since those are actually little DC motors, not just coils, you should add capacitors across each coil to squash the commutation noise. See this cross thread.
The issue being the diode only protects the transistor by removing voltage spikes from the top of it. There will however also be large spikes between the series motors as commutation happens. That will be picked up elsewhere in your circuits and probably on your AM radio.
Hooking them up like that you may also find things do not quite work as you expect. One parallel path may hog all the current.
Wiring motors in series is also a bad idea if the are not mechanically coupled. Whichever motor has the least friction will run faster than the other. Wired that way you have built a "differential drive". You will find it quite easy to stall one and have the other go twice as fast, if it does not do that on it's own.
