I am still a beginner but I already managed to design a circuit around a PSoC 4 device with some peripherals (5V powered sensors, 5V powered mini fan, 5V step-down regulator for the main power supply and 5V step-up regulator for the sensors and fan). The circuit will be powered with 5V DC main power supply which will be either a wall plug supply or a power bank with minimum 5V voltage but it does not matter I hope.
Now I would like to add a battery backup power in case the main power supply fails or will be removed, just to be able to put the chip in sleep mode and keep the real time clock running, which is provided by the chip.
So far the application description.
Now to ensure that my backup battery lasts a long time and really provides current for the sleep mode only, which will be some uA, I would like to cut it off the circuit in case the main power supply is available. I woud like to use a N-MOSFET as a low side switch for this, but I am not really sure where to attach this mosfet in my existing circuit. After some research I came up with the solution in the attached schematic image, and here are my questions:
1) Is this correct that way in general?
2) Do I need the N-mosfet switch at all? I found several statements which state, that the battery won't be used as long as it's voltage is lower than the voltage of the main power supply.
3) I heard in some tutorial about power sources, that it's in general not wise to share a common ground between grounded (my 5V wall plug power supply) and floating power sources. Is this realy a "problem" in my case?
4) Can I switch the possition of D7 and U4 or is it bad when Vout of U4 gets the battery voltage?
Noe: Vgate will be set high by the PSoC 4 device as soon a voltage drop is detected by a voltage comparator, to switch the mosfet on. The power for this critical time, between the main supply failure and switching on the battery backup, will be provided by a 220uF capacitor.
I will appreciate any hints on how to make a simple battery backup for a long battery life time.
Artur Cichosz
  • 125
    Many would opt for a P-FET on the high side. You arrangement has its benefits too. How are you planning to charge your battery? – winny Apr 09 '17 at 21:18
  • I do not plan to charge it at all. I plan to use a CR2032 cell to be a replaced like the CMOS battery in a PC. – Artur Cichosz Apr 09 '17 at 21:22
The key to these circuits is that you have to find a way for your circuit to turn itself on provided there is no voltage applied from the external power source. Many very basic reverse battery protection circuits (that go beyond a series diode) can actually be used with litte to no modification for this purpose - I would suggest starting there. Take a look at figures 2 and 3 from his application note from TI:
http://www.ti.com/lit/an/slva139/slva139.pdf
Joren Vaes
  • 12,376
  • 64
  • Hi, thank you for you reply. I will have a look into this, but my case assumes that there is allways some voltage applied, either main power supply or the battery backup voltage or (I did not mention it, sorry) a decent electrolythic capacitor e.g. 220 uF which should provide the power for the voltage comparator to detect voltage drop and to switch the n-mosfet on. – Artur Cichosz Apr 09 '17 at 21:13
  • The Psoc device is fully operational with a voltage range 1.7-5.5 V, so I will be allways able to put it in sleep mode and wakeup given that one of the three powerr sources above deliver power as expected. – Artur Cichosz Apr 09 '17 at 21:16
  • Joren, after I while I took a second look at the resource from TI you linked. Why is there (figure 2/3) a diode in parallel with the FET? It is conductive in the same direction as the FET itself so what is the point here? – Artur Cichosz Sep 18 '17 at 08:55
  • @ArturCichosz that is not a external device that has been added, but is there to illustrate the internal body diode of the device. It is there because of the way a mosfet is built up. I discussed it in this question: https://electronics.stackexchange.com/a/308885/34873 – Joren Vaes Sep 18 '17 at 09:36
