12
I'm in the process of learning to design PCBs and understanding electronics design. For a project, I need to charge a 3.7V LiPo battery. I also want to protect it from over‑charging / over‑discharging.
I've been experimenting with boards that use the TP4056 together with a DW01 battery protection IC and FS8205A dual N-channel MOSFET.
The datasheets are available here:
The pre-built modules are very cheap - here is an example on AliExpress:
Image of battery charger module based on TP4056 + DW01 + FS8205A
They seem to work, but I would like to know what the circuit is actually doing before I use it :)
I've only found one schematic with these three components combined:
schematic diagram
I'm having a hard time to figure out if this circuit is correct. If I understand correctly, the dual N-channel MOSFET is basically 2 switches in one package. Those two MOSFETs are triggered by pins 1 and 3 of the DW01, which are described as:
  • DW01 pin 1: MOSFET gate connection pin for discharge control
  • DW01 pin 3: MOSFET gate connection pin for charge control
So basically the two MOSFETs in the FS8205A are switching off the flow to B-, when DW01 tells them to do so.
I understand that this would work when the over-discharge control kicks in, no power would be flowing from B- to OUT-
However what I don't understand, is how this would work with the over-charge protection? When that kicks in, no power should be flowing from the charger to the battery, however, the device that is connected to OUT+ and OUT- should still be able to work, but it seems like B- would not reach OUT-
SamGibson
  • 17,231
  • 58
ErikL
  • 399
  • The charger is connected to out+ and out-. Over-charge protection only operates when voltage from out+ to out- is above the cutoff which could be something like 4.25V. Only the protection IC and FET's should be connected to B-. So the protection IC will always have power unless the cell voltage is extremely low. – user57037 Apr 08 '17 at 19:30
  • "however, the device that is connected to OUT+ and OUT- should still be able to work" - the PCM doesn't just protect against over-charge, but also over-current and over-discharge. It only has one switch, so it must disconnect the cell no matter what fault was detected (which might even be over-voltage coming back from the load). Its primary purpose is to prevent the battery from blowing up. It should not trip unless some part of the device (charger, low voltage cutoff etc.) fails, in which case making the device inoperable is a desirable feature. – Bruce Abbott Apr 09 '17 at 08:16
Protection circuits are usually distinct from charging circuits. Many battery packs are designed with the intention of being charged by a dedicated unit that will control the charging process.
The charging process may involve cell balancing, if the pack contains a large number of cells in series, generally 4+ cells in series (4S, 14.4V) nominal will require balancing, 3S and lower it's also a good idea to balance for the health and longevity of your battery, but not necessarily required. Balancing circuits can get complicated and typically involve a BMS (battery management system) composed of a dedicated IC and multiple external mosfets, There's a project on github that seeks to create an openBMS system. This might be a good resource if you are looking for more information.
The charging cycle for lithium ion batteries can be quite complex, especially in the case of multiple cells in series, but typically involves 4 basic steps:
  • Read voltage, if lower than a certain value (typically 2.8V or so for Li based cells) then begin trickle charge until cell reaches safe charging level, doing this avoids damaging the cell.
  • constant current charging: the cell is charged at a constant current, typically .5C-1C for normal charging, e.g. for 1000mAh battery, charge at between 500mA-1000mA.
  • constant voltage charging: once battery reaches a certain point (typically about 60% of total charge (3.8V or so) begin charging at the target final voltage (4.2V for normal 1000 charge cycle expected life) you can go higher, and it will give you more battery life, but it will reduce the life of the battery.
  • Maintenance charging: The battery has a natural discharge rate in the neighborhood of 8% at 21 °C per month, when the battery drops below 10% of full charge, recharge to target voltage using constant voltage charging. This is configurable depending on application.
Notes: there are ICs that will handle the bulk majority of this for you, otherwise you will need to resort to designing an MCU controlled circuit with external boost/buck converter, or linear regulator.
The protection circuit (PCM) is fairly simple and often times integrated right into the individual cells, these cells are typically labeled: protected, or unprotected. The PCM will monitor things like: input voltage, output current, cell voltage, temperature, etc. They often times are not that robust and should be considered a last resort in a critical system. Alarms should be going off if the PCM is ever triggered.
To answer your specific question: the DW01 is optimized to favor the charger in the case of overcharge, so the charger would remain connected to the circuit, suppling nessesary voltage, while the battery is disconnected, TP4046 looks like it is designed to handle up to 8V and as a linear charger it will be dissipating excess voltage as heat. These ICs are often thermally protected and will automatically shut off in the case of excess current or voltage. If there is an overcharge, it means the circuit is likely destroyed, thus it is nice to try to disconnect the battery in this case, as it would would pose a significant safety risk.
Also, remember that mosfets contain internal diodes, so even if charge protection mosfet were to be turned off, the battery would still be attached to the circuit as long as the voltage on the drain side of the mosfet is below a certain voltage.
John Evans
  • 304
  • re: "Protection circuits are usually distinct from charging circuits" In this case, if you're just going to use the little board as a charger (as many people do) you may conveniently bypass the protection circuit by removing R5 and tying B- to OUT-. This lowers the B- to ground potential which could be useful for purposes of, say, adding a voltmeter display. – David M. Perlman Jan 09 '20 at 08:25
Tipically the initial constant current ionizes the battery chemistry and the voltage cycle adds the potential. if the charger has no enough current thevoltage cycle may find larger resistance and thus try to push more voltage than battery requires causing trouble. Charger is supposed to have plenty of current for the initial chemistry cycle at LiPos..
Anil
  • 26
