I'm using the STM32F4DISCOVERY board and I am trying to read a file from a micro SD card, and treat the data. I'm using the following functions
int main(void)
int i = 0;
HAL_Init();
/* Configure the system clock */
SystemClock_Config();
/* Initialize all configured peripherals */
MX_GPIO_Init();
MX_ADC1_Init();
MX_SDIO_SD_Init();
MX_TIM10_Init();
MX_FATFS_Init();
MX_USART2_UART_Init();
create_filter_bank();
ret = f_mount(&filesystem, buff_mount, 1);
ret = f_open(&file, WANTED, FA_READ);
ret = f_read(&file, header, 78, &br);
ret = acquire_voice_from_file(&file);
f_sync(&file);
f_close(&file);
// Some other code
FRESULT acquire_voice_from_file(FIL* file){
file_pointer = HEADER_WAV_SIZE;
acquired_frames = 0;
FRESULT read_res;
while(acquired_frames < NUM_ACQUIRE_FRAMES){
file_pointer += FFT_SIGNAL_BYTES/2; // Need a correlation between frames
read_res = read_frame_from_file(file);
acquired_frames++;
// Some Other Code
return read_res;
FRESULT read_frame_from_file(FIL* file){
int i = 0;
FRESULT res;
res = f_lseek(file, file_pointer);
res = f_read(file, bytes, FFT_SIGNAL_BYTES, &br);
if(res != FR_OK){
return res;
for(i = 0; i < FFT_SIGNAL_LENGTH; i++){
curr_frame[i] = (bytes[2*i+1] << 8) + bytes[2*i];
// Multiplying by Hamming window
curr_frame[i] *= (0.54 - 0.46*cos(2*PI*i/((float)FFT_SIGNAL_LENGTH)));
return res;
All the constant values such as WANTED, FFT_SIGNAL_BYTES, and so on, are declared on the header file correctly. In the main function, f_mount, f_open, and f_read, return the result FR_OK and the data is correctly read. But then in the function "acquire_voice_from_file", one or two frames are successfully read, and then I get the value FR_DISK_ERR from the function f_read in the function "read_frame_from_file". I assume that my hardware configuration is alright since the first bytes are read correctly, but I don't manage to solve the issue and read correctly the next frames. The size of the frame I'm trying to read is 2048 bytes (FFT_SIGNAL_BYTES = 2048). Is there an issue to read big files with FATFS ? And if so, is there a solution ? Many thanks for your help.
