I'm using a 32.768 kHz crystal FC - 12M on a board with STM32L433 in a LQFP48 package. There are two 10pF C0G load capacitors used.
The problem is that on one of the boards (I have two of this revision) the LSE oscillator won't start until I touch it with a scope probe (10x setting, 10M, 16pF). After that touch with the probe, it stabilizes in a second or two and seems to work correctly until I unplug the board.
I've tried with 4.7pF, 10pF, 12pF and 22pF load caps. (the other board that works has 12pF installed).
I've tried cleaning the board with iso alcohol, thinking flux residue might cause this.
I use short traces and ground underneath the oscillator.
Oscilator
Any ideas?
pkuhar
  • 473
    If on one board it works correctly it's looks like soldering defect. Try to resold capacitors, crystal and MCU pads. – Fasset Mar 20 '17 at 06:56
  • I agree with Fasset, this is probably bad solder joint somwhere (try resolder the crystal) or the crystal might be damaged. – MathiasE Mar 20 '17 at 08:08
  • Murata recommends to use a symmetric layout and no ground plane under oscillators - haven't had much issues so far not following this, but might make a difference. – Arsenal Mar 20 '17 at 08:47
  • Try adding some output series resistance. Maybe 33 ohms. It could be that the output of the STM32L433 isn't low enough resistance to get the required phase shift to start oscillation. – Andy aka Mar 20 '17 at 10:06
  • http://www.st.com/content/ccc/resource/technical/document/datasheet/f7/a0/fc/27/24/4e/4f/3f/DM00257192.pdf/files/DM00257192.pdf/jcr:content/translations/en.DM00257192.pdf See AN2867 - Application note - Oscillator design guide for STM8S, STM8A and STM32 microcontrollers – StainlessSteelRat Mar 20 '17 at 17:39
  • Specifically Section 7. – StainlessSteelRat Mar 20 '17 at 17:46
  • @Fasset I'm guessing if it wasn't soldered correctly if would not oscillate after you "stimulate" it with a probe. – pkuhar Mar 20 '17 at 22:56
  • Btw: The other boards starts slow also. about 3-4s, but does do not fail. I have a retry loop on the RCC init function.(the hal rcc init itself times out in 5s) – pkuhar Mar 20 '17 at 22:58
It was a problem with the no-clean flux. After two days the remaining flux residue evaporated and now it's fine on all boards.
A reference to this problem and a high leakage current caused by it can be found in this Application note from TI MSP430™ 32-kHz Crystal Oscillators
pkuhar
  • 473
    Thank you very much. I had the same problem with ATXMEGA32a4U. I had 4 on the same board, two of them were RTC oscillators which would not start. In my software, the line: "Bitwait Rtc_status.0 , Reset " never passes because the RTC oscillators do not start. Whenever I put a multimeter probe on it, it starts working. I had washed my boards before and I put a capacitor on the crystal pin, but without any result. As I was readig this post, I put an hot air on the MCU pins again and some oil came out. I tested it and it works fine now. – Shahriar Farmanesh Jun 02 '19 at 13:55
