I am trying to reduce the current consumption of my Atmega328 -Arduino- by using the sleep modes. In my code, I want to wake-up every 10ms, read the value from ADC, and go to the sleep mode again.
There are some useful instructions (here and here), but most of them are either based on Watch Dog Timre or external interrupt from pins.
Here is the simplified code of mine, but doesn't work (it doesn't go to the interrupt handler function):
In the setup, I take care of the Timer and its handler:
void setup() {
   Serial.begin(19200);
   Timer1.initialize(10000);  //10ms sampling rate
   Timer1.attachInterrupt(ReadMyADC,10000);
   power_spi_disable(); // SPI
   power_timer0_disable();// Timer 0
The rest of the code including loop() is as follows:
void ReadMyADC(){
    sleep_disable();
    PRR = PRR & 0b00000000;
    Serial.print("sth");
    power_adc_enable(); // ebable ADC converter
    //Read ADC
    power_adc_disable();
void loop() {
    // ----------------low power ---------------
    PRR = PRR | 0b00100000;
    sleep_enable();
    set_sleep_mode(SLEEP_MODE_STANDBY);
    EIMSK |= _BV(INT0);            //enable INT0
    ADCSRA = 0;                    //disable ADC
    cli();
    mcucr1 = MCUCR | _BV(BODS) | _BV(BODSE);  //turn off the brown-out detector
    mcucr2 = mcucr1 & ~_BV(BODSE);
    MCUCR = mcucr1;
    MCUCR = mcucr2;
    sei();                         //ensure interrupts enabled so we can wake up again
    sleep_cpu();                   //go to sleep
    sleep_disable();               //wake up here
    Serial.print("Wake\n");
Apparently, Timer1 is not able to exit the cpu from sleep mode. Do you have any idea how to manage that, or where the problem is?
Farzad
  • Look at the data sheet for the Atmega. You'll find that for all deeper sleep modes than idle and adc noise reduction mode only the wdt, an external interrupt, or an asynchronous timer (external 32kHz quartz) can wake up the CPU. – JimmyB Mar 18 '17 at 14:39
Deeper sleep modes turn off more of the chip to reduce current consumption.
The deeper modes turns off the timer counters since they consume quite a bit of current.
Use the watchdog timer in interrupt mode instead, or for max power down, use a micro driven external RC decay to interrupt the micro after a short period.
Trevor_G
  • 46,364
  • 68
  • 151
  • the watchdog timer does not support interrupts with higher frequency than 64Hz. So, it seems that for a frequency of 100Hz, I need to use Timer1 at SLEEP_MODE_IDLE with unnecessary peripherals shut down. – Farzad Mar 19 '17 at 11:10
Sleep_Mode_Standby does not allow Timer1 to run since the clock domain is turned off. You can only use Timer1 in Sleep_Mode_Idle, your code should work if you use that mode.
Use the WDT since it has it's own clock at 128 kHz that is enabled whenever it is on.
Code such as this may work for you:
#include <avr/sleep.h>
#include <avr/wdt.h>
void setup () { }
const byte LED = 13;   //Nano LED
void flashLED ()
 pinMode (LED, OUTPUT);
  // Flash the LED
 for (byte i = 0; i < 10; i++)
    digitalWrite (LED, HIGH);
    delay (50);
    digitalWrite (LED, LOW);
    delay (50);
// Watchdog ISR routine
ISR (WDT_vect)
   wdt_disable();  // disable watchdog
   // Return from ISR
void loop ()
  flashLED ();
  // disable ADC
  ADCSRA = 0;
  // clear all MCUSR flags
  MCUSR = 0;
  // allow changes, disable reset pin
  WDTCSR = bit (WDCE) | bit (WDE);
  // set interrupt mode and an interval
  WDTCSR = bit (WDIE) | bit (WDP2) | bit (WDP1) | bit (WDP0);    // set WDIE, and 2 second WDT delay
  wdt_reset();  // Start the timer
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  noInterrupts ();           // timed sequence follows
  sleep_enable();
  // turn off brown-out detector
  MCUCR = bit (BODS) | bit (BODSE);
  MCUCR = bit (BODS);
  interrupts ();
  sleep_cpu ();
   // Sleep here in powerdown state
  // Return here after WDT return from ISR
  // disable sleep
  sleep_disable();
  // Do your thing here
Jack Creasey
  • 21,428
