I am working on a project wherein, I need to read the Analog outputs from 4 sources and convert them to a digital value using a single ADC module on the STM32F407 microcontroller. I want to sample the ADC values every 50ms and therefore have decided to use it in polling mode and have a timer Interrupt every 50ms to trigger the ADC reading. I am using the STM32 CubeMX software to generate initializations for me.
Here are the ADC initializations:
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV2;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.NbrOfDiscConversion = 0;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 1;
hadc1.Init.DMAContinuousRequests = ENABLE;
hadc1.Init.EOCSelection = DISABLE;
And in my main function:
while (1)
/* USER CODE END WHILE */
g_ADCValue = HAL_ADC_GetValue(&hadc1);
Now this works when I have one ADC channel enabled, but how do I read from more than 1 channel at the same time? How does the GetValue()
function return the ADC value of a certain channel? Also I know I do not want to use ADC interrupts for this as I want to sample the ADC at particular intervals of time (every 50 ms), but should I be using DMA? If so, how would I do that?
Thank you very much for all your help!
