I am using STM32F46ZG NUCLEO discovery board. My code is like:
int main(){
  HAL_UART_Transmit_IT(&huart1, buff, 5);
  while(1)
    do something;
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart){
My code has no RTOS, and I want to continuously transmit the 5 bytes. Once the previous interrupt transmit finishes, I want to transmit 5 bytes right away. So can I just call HAL_UART_Transmit_IT() in its own call back function?
SoreDakeNoKoto
  • 1,635
linkopen
Sure, just make sure to avoid race conditions and blocking in anything called from an ISR. For example, if HAL_UART_Transmit_IT blocks for buffer space to become available, you must not call it from an ISR as this will almost certainly cause a hang. Also, HAL_UART_Transmit_IT must be reentrant as your interrupt could fire while HAL_UART_Transmit_IT is executing in your main loop. Another option would be to set a flag and handle the transmission somewhere else.
alex.forencich
  • 40,694
  • 68
  • 109
  • Thank you for the reply. Setting a flag was what I did initially, but when in the main loop this flag can get processed is random, and I want to first take care of transmitting 4 packets of just 2 words in each packet, and the delay among each packet gets transmitted is even. – linkopen Mar 16 '17 at 13:16
