For a hobby project of mine, I'm thinking about connecting some old 5V SRAM chips like this one to a 3.3V - capable FPGA. The target frequency is 50MHz. After some simulator experiments I found out that a simple voltage divider could work:
This gives a nice 0.2..3.0V peak to peak signal on the 3.3V side when driven by 5V side. In the opposite direction however, the output signal is only 0.4..2.6V peak to peak, which is kind of within the spec for a W24512AK (\$V_{0H}=0.8V\$ and \$V_{1L}=2.2V\$) but the margin isn't great. I wonder if this will work at all in practice.
So I'd like to improve the margin by using an active level converter, but as far as I can see, all simple schematics (e.g. the ones listed here) have a terrible frequency response. The only viable solution I see is to buy some TXB0108 which can reach 100Mbps at 3.3V.
Is there a level converter schematic I have overlooked? As such, it doesn't have to be truly bidirectional since the \$\overline{WR}\$ signal is accessible and can be used to enable/disable shifters in each direction.
Dmitry Grigoryev
  • 25,576
  • 45
  • 106
    How about a [74LVC245 Octal Bus Transceiver](http://www.ti.com/lit/ds/symlink/sn74lvc245a.pdf) running at 3.3V placed in between. Inputs are 5V compliant. – Tut Mar 15 '17 at 15:39
    @Tut: but what about 3.3V --> 5V direction? – Curd Mar 15 '17 at 15:45
  • @Curd ... Dmitry will need to verify and see if he's satisfied with the margin, but it looks like the VOH specs will be high enough to exceed the VIL = 2.2V mentioned above. I don't know what the input current requirements of the SRAM are. – Tut Mar 15 '17 at 15:52
  • @Tut It's a CMOS SRAM with 8pF input capacitance. At 50 MHz this means about 10 mA, I believe. I wonder how much of an improvement this transceiver will be over my voltage divider. – Dmitry Grigoryev Mar 15 '17 at 15:59
    +1 for the suggestion by @Tut of an LVC245 over two HCT244s and eight resistors, it also has a higher current drive capability – Finbarr Mar 15 '17 at 16:16
  • If you are not satisfied with the levels, also consider [SN74LVC4245A Octal Bus Transceiver and 3.3-V to 5-V Shifter With 3-State Outputs](http://www.ti.com/lit/ds/symlink/sn74lvc4245a.pdf). – Tut Mar 15 '17 at 16:31
    I hadn't really payed attention to your 50Mhz target. If speed is an issue, I have to agree with the suggestion by Anonymous to get 3V3 SRAM and skip the level translation. – Tut Mar 15 '17 at 17:31
  • @Tut It's a hobby project so the target is somewhat flexible, since I have a spare PLL laying around. I already have some 3.3V SDRAM which beats old SRAM chips in both size and throughput. I'm just trying to get familiar with high-speed circuits. – Dmitry Grigoryev Mar 15 '17 at 17:53
I am slightly skeptical on your architecture. I used ALVC256 chip for the 3V3-5V conversions, and even with this would-be-correct architecture there're several issues which, at some circumstances, may make device malfunction.
Consider the following:
  • 50 MHz is 20 ns cycle, SRAM you are going to use is 15 ns read/write cycle. You have slack of only 5 ns to ensure that buses (address and data) are stable and select proper memory cell for access;
  • Mismatching impedance will cause spikes and false positives at the SRAM side, killing your 5 ns slack and potentially accessing (reading/writing) wrong data. This may require very fine tuning to work properly under all conditions (e.g. temperature, power source condition).
If you want well working device, then
  • Get 3V3 SRAM, and connect it to the FPGA without any converters using series resistors (which you can change to tune for impedance);
  • OR relax frequency conditions down to, let's say, 20 MHz (50 ns cycle).
Anonymous
  • 6,908
  • 41
  • Is there a chance that my passive level shifter will work at, say, 20MHz? – Dmitry Grigoryev Mar 15 '17 at 16:50
    I would ask different question - what will be the reliability of the solution? I *think* you can make it working, given you already simulated circuit, you will use scope to test waveforms and tune resistor and capacitor values, ensuring slopes are acceptable and there're minimal distortions to square shapes, and you do not create higher-order issues (like interconnecting 3V3 and 5V suppliers creating excessive current within chips). – Anonymous Mar 15 '17 at 20:06
    I actually made simple resistor dividers (without the caps), and your estimation of 20MHz turned out to be pretty accurate. Thanks again. – Dmitry Grigoryev Mar 30 '17 at 15:40
  • 3.3V → 5V:
    a 74HCT244 powered by 5V (s. datasheet: min. High level input voltage) should work.
  • 5V → 3.3V:
    a 74HCT244 powered by 3.3V and series input resistors to limit input current via protection diodes.
This solution needs each buffer enabled for each direction (as you have addressed in your last sentence).
Curd
  • 16,043
  • 43
  • Thanks! Any reason to prefer this over a single TXB0108 chip? – Dmitry Grigoryev Mar 15 '17 at 15:43
  • Availablity! (I'v never heard of a TXB0108) – Curd Mar 15 '17 at 15:48
  • Fair enough! I can get both, but 74HCT244 seem to be substantially cheaper, even considering I'll need two. – Dmitry Grigoryev Mar 15 '17 at 16:01
  • BTW, is there a reason why your have a bold `T` in the first case? – Dmitry Grigoryev Mar 15 '17 at 16:03
    Yes, of course. There is a 74HC logic family and a 74HCT logic family. Both are "high speed" CMOS families but they have different threshold levels (the HC**T** is compatible to the LS ("Low power Schottky") familiy, i.e. the min. H input voltage is lower). See family datasheet http://www.ti.com/lit/sg/sdyu001aa/sdyu001aa.pdf page 4; \$V_{IH}\$ for HCT is 2V vs. 3.5 for HC. – Curd Mar 15 '17 at 16:58
