Why are the heaters generally 6.3 V (or multiples thereof)?
Does it make for an easy transformer winding ratio when used in countries with 120 VAC or 240 VAC mains?
They often pull quite significant current, and as there's generally a higher voltage supply available, a higher voltage and thinner wire could have been used.
What are the advantages of having a low voltage supply for the heaters?
Peter Mortensen
  • 1,676
Colin
  • 4,499
    I would have a guess and say its historical, something to do with old valve radios and batteries. Also its half of a standard 12V lead acid battery terminal voltage at full charge (~12.6V) – crowie Mar 15 '17 at 07:50
  • Thanks for your comment, that kind of makes sense, but even then wouldn't a 12volt heater have been more sensible, otherwise you need multiple heaters in series, or some other element to waste quite a lot of power. – Colin Mar 15 '17 at 07:53
    Just a resistor really, perhaps old radio batteries were 6v? – crowie Mar 15 '17 at 08:02
  • Nobody ever said valves were efficient :) – crowie Mar 15 '17 at 08:02
    A lead acid cell has a voltage of 2.1 volts. Old valve radios used to use a battery containing 3 of these to power the heaters. – Keith Miller Mar 15 '17 at 08:03
    There were also "2V" valves for portable radios, and 4V was the standard for many pre-WW2 valves in Britain, using 1 and 2 cells for the heater supply respectively. –  Mar 15 '17 at 10:05
  • @Colin__s Could you add some context for readers that do not know the kind of vale in question? If 'valve' is unknown, the title could refer to tube shaped room heaters or so - at least it confused me. Hey, but it makes me feel young to not know something about vacuum tubes! – Volker Siegel Mar 15 '17 at 11:03
  • @VolkerSiegel I have changed the title to be thermionic valve. :) – Colin Mar 15 '17 at 11:07
  • @Colin__s In incandescent bulbs the higher the voltage, the thinner the filament. The thinner the filament, the shorter the lifespan. As a tube is quite expensive and its dominating failure mode is burnout of the filament, it's obvious that lower voltage/higher current is very desirable. So, from purely theoretical side the actual question is "why not **lower** voltage than 6.3V?". And you already have the argument: it increases loses outside the bulb (eg on the bulb socket). So 6.3V looks like a compromise between long life and a feasible socket. Then backward compatibility set it in stone. – Agent_L Mar 15 '17 at 14:49
  • All that battery stuff in the various answers makes sense, but I always imagined that it had some relationship to multiples of pi, and winding transformers. – MickeyfAgain_BeforeExitOfSO Mar 15 '17 at 18:29
When vacuum tube radios were invented, only a fraction of houses had mains electricity, therefore, first radios (and their tubes) were battery powered, they used three batteries:
  1. "A" battery for heaters. As heaters require a lot of power, this was a rechargeable battery. A 6V lead-acid battery usually is at 6.3V, so this voltage was chosen as standard.
  2. "B" battery for anodes. This was a high voltage non-rechargeable battery, it lasted longer than the "A" battery though.
  3. "C" battery for negative grid bias. As grids do not really use any current, this battery lasted very long.
I guess the 6.3V heaters continued to be used just because there was no real reason to change the voltage. Using a high voltage (220V) heater would be problematic because you would need a very thin wire for the heater (220V 9mA heater would need a really thin and long wire) and the high voltage may affect the signal in the tube.
Some tubes were designed to powered from the mains, their heaters were designed so they all draw the same current (at different voltages).
Later tubes intended for battery operation used 1.2V or 2.4V heaters which is a multiple of a NiCd battery voltage.
Pentium100
  • 6,550
  • 32
  • 39
  • Battery powered valves(tubes) were usually driven from dry cells (zinc carbon) so were rated at 1.4V. NiCd cells were hardly ever used although they would be compatible. – Kevin White Mar 15 '17 at 20:46
  • @KevinWhite, the few battery tubes I encountered had nominal filament voltage of 1.2V or 2.4V (some, like 2П1П, can be connected as series or parallel heater with 1.2 or 2.4V). On the other hand, if powered from a dry cell, the filament voltage still works because most of the time battery voltage will be within the tolerance of the filament (slight overvoltage with new battery, slight undervoltage with almost dead battery). – Pentium100 Mar 16 '17 at 05:13
6.3V tubes became common at the time the first car radios (and, I suspect, other vehicle-mounted electronics, usually not for personal civilian use) were developed. 6V was the standard for car batteries back then; 12V applications were easily dealt with by intelligently building series circuits of heaters - heater currents @6V were specified in the datasheets. DC voltage converters were awkward and costly to build in these days (though often needed for the anode voltage anyway - but why make them bigger or more complicated than necessary), so designing a valve series from the ground up for car use was the most economic solution.
rackandboneman
  • 3,085
The voltages were selected to minimise the current from available batteries to gain the longest duration of heating.
However as the voltage increased the effects of the voltage on directly heated filaments would affect the bias point at the non grounded filament end related to the grid voltage. It would cause a spread in the bias and gain if DC heated with possible problems in reaching cut off. It would also cause a massive AC component in the cathode current that would be amplified if the filament was AC heated.
Some of this noise was removed by using centre grounded AC filaments to have the opposite ends cancel some of the problem and also indirect heating of the cathode when practical to hide the filament potentials.
A voltage of 6.3V was a compromise that took as much of the limitations into account as possible. It was close to the 2V and 1.5V cell chemistry multiples, that let one use 3 lead acid cells or 4 zinc chloride cells.
KalleMP
  • 4,039
  • 32
