I am trying to understand why there is variations in resistance values, in other words, why there is difference in the value of the resistance between color code and the measured resistance. Also, how to manufacture more precise resistors?
pipe
  • 13,748
  • 42
  • 72
Canberk
    If you buy a hundred tins of tomatoes would you expect every tin to weigh EXACTLY the same weight? – Andy aka Mar 08 '17 at 08:58
    As with most things in life accuracy is a function of price. You can control the manufacturing processes and materials very well and get good tolerances, you can then test and reject or trim them to ensure an even tighter tolerance. But all of that costs more. Most of the time you don't need the accuracy so why pay for it? – Andrew Mar 08 '17 at 09:03
  • See http://electronics.stackexchange.com/questions/39344/why-are-we-still-using-resistors-with-5-tolerance-while-they-can-even-manufactu?rq=1 – pjc50 Mar 08 '17 at 09:29
    how to manufacture more precise resistors? - basically produce something that is near enough and then trim the value using lasers to obtain the accuracy required. – JIm Dearden Mar 08 '17 at 10:21
  • ... because the last ring allows for the value to deviate by silver or gold or red or brown percent from the value coded in the first three or four rings. (please mentally add the appropriate emoji) Or are we talking about huge variatens not inside the specified tolerace? Then, we might get into an interesting question about resistor failure modes or measurement problems... – zebonaut Mar 08 '17 at 10:28
    first of all note that the tolerance is indicated as a *part of the color code* – dlatikay Mar 08 '17 at 10:53
Andy aka is quite right above, statistically if you manufacture hundreds of resistors there will be some statitical variation in the output. Thats said, resistor precision depends on several such as resistor techonology (wire-wound, chip, etc), temperature of operation (the resistance of a straight piece of wire will vary with temperature) and frequency of operation.
M_Breeny
  • Some technology also has a really measurable voltage coefficient, that you seldom see in the short form datasheets, but the better manufacturers will fess up to in the full data. – Dan Mills Mar 08 '17 at 22:52
Modern carbon-film resistors are actually manufactured to a nominal 0Ω, then laser-trimmed to the desired value. A laser burns off bits of carbon to increase the resistance, then the resistor is encapsulated, printed, and packaged on tape.
However, the laser doesn't burn off a consistent amount of carbon. The manufacturer increases precision by testing the resistor and burning off more carbon to approach the target value. The more tests and adjustments are made, the higher the precision.
Of course, repeatedly adjusting the resistor consumes time, which makes precision resistors more expensive to produce.
To maintain precision, the resistor is also tested after being encapsulated and fitted with pads, in case a manufacturing defect pushed the value out of spec.
