First of all I am no electrical engineer (would love to be one!) so apologies upfront if this question is only fit for the sci-fi section. If it is, I'd still like to see a solution to this:
Appliance is connected to switch X which is plugged into mains AC socket. Switch is set to ON, but appliance stays off. Upon a power failure, switch X detects the power loss and upon power resumption, becomes "active" and allows power to flow through, powering up the connected appliance. Possible reset of switch X through second power off and on at the AC socket or a button push.
Is this available/ possible?
I want to hook up a vacuum pump to an aquarium sump set-up but don't need that appliance running 24x7. Upon a power failure, the sump will fail. When power resumes, the sump will still not work, requiring the vacuum pump to draw water into the pipes, hence the need for this relay.
Thanks in advance!
