I am again involved an RF design and I am unsure on how to connect up the Balun, minicircuits application note suggests that it is dependant on the polarity/phase of the input signals (which makes sense) but I have seen conflicting implementations of the Balun in evaluation boards from analog devices.
The app note suggests a configuration like such:
{**+** ---- [P* S] --- **Out**}
{**-** ---- [P S*] --- **Gnd**}
In order to achieve an output which is twice that of the input signal, and this is indeed my aim as I am using a frequency synthesizer with complementary RF outputs.
In the evaluation board I have seen:
{**+** ---- [P S] --- **Out**}
{**-** ---- [P* S*] --- **Gnd**}
This is also complicated by the fact I am using a config K balun (Tri-Filar) from minicircuits, which also states in the datasheet that the primary port is/should be connected to ground.
So my question is, does the way in which I connect my signals to the Balun matter (either Primary or Primary*)? and should I be concerned about the config K datasheet telling me to connect the primary to ground?
Many thanks
