I found some FM transmitter circuits with the MAX2606 VCO.
Can I replace R1 with the DAC output from an AVR microcontroller? Or can I connect the DAC directly to Pin 3 of the MAX2606?
Yes you can but be aware of noise on the output of the DAC especially when changing DAC values - you get a bit of capacitive coupling from the clock and this might require a bit more filtering than just the 270 ohms and 2200 pF will bring about.
For this reason, it's not generally recommended to directly couple a DAC output directly to the TUNE input.
ADDED SECTION Given that the "so-called" DAC output may be PWM output with possibly some filtering, I would advise to make any filtering as decent as possible. The PWM frequency needs to be kept as high as possible and you will probably need at least a 2nd order low-pass filter with a bandwidth of sub 10 Hz (or better).
Yes and Yes.
all the chip cares about is a voltage there. doesn't matter how that voltage is generated.
