I have met a emitter follower design example in the Horowitz-Hill's book (scheme is below):
And I don't understand why the resulting steps is correct:
Step 1. Choose \$V_E\$. For the largest possible symmetrical swing without clipping, \$V_E = 0.5V_{CC}\$, or \$+7.5\$ volts.
Step 2. Choose \$R_E\$. For a quiescent current of \$1 mA\$, \$R_E = 7.5k\$.
Step 3. Choose \$R_1\$ and \$R_2\$. \$V_B\$ is \$V_E+0.6V\$, or \$8.1V\$. This determines the ratio of \$R_1\$ to \$R_2\$ as \$1:1.17\$. The preceding loading criterion requires that the parallel resistance of \$R_1\$ and \$R_2\$ be about \$75k\$ or less (one-tenth of \$7.5k×\beta\$ ). Suitable standard values are \$R_1 = 130k\$, \$R_2 = 150k\$.
So, once again all known values: $$ V_{BE} = 0.6 V \\ R_1 = 130K \\ R_2 = 150K \\ R_E = 7.5K \\ \beta = 100 $$
My question is about values for \$R_1\$ and \$R_2\$. The maximum current through the divider without connected load is: $$ I_{div} = \frac{V_cc}{R_1 + R_2} = \frac{15}{280 \cdot 10^3} \approx 54 \mu A $$
When we connect emitter follower to the divider, there must be a base current \$I_B\$ that is: $$ I_B = \frac{I_E}{\beta + 1} = \frac{1ma}{100 + 1} \approx 9.9 \mu A $$
Hence we could calculate output voltage of the divider after connection of emitter follower: $$ I_{R_2} = I_{div} - I_{B} = 54 - 9.9 = 44.1 \mu A $$
Hence, we'd get a output voltage from the divider: $$ V_{div} = V_{R_2} = I_{R_2} \cdot R_2 = 44.1 \cdot 10^{-6} \cdot 150 \cdot 10^3 \approx 6.62 V $$
So, we would get a \$6 V\$ output from the emitter follower instead of expected \$7.5 V\$.
Could you tell me where I'm mistaken?
P.S.: There is also a screenshot from simulator:
vpetrigo
  • 113
  • Step 4 - if you are dissatisfied with the output not being 7.5 volts, adjust one of the bias resistors. – Andy aka Feb 12 '17 at 11:01
  • Thank you. It's the obvious step. =) But am I right with my statements? – vpetrigo Feb 12 '17 at 11:03
  • Yes you are indeed. – Andy aka Feb 12 '17 at 11:06
  • I don't understand why they point out that we should meet the condition \$R_source = R_1 || R_2 \ll (\beta + 1) R_E\$, but do not mentioned that it also should be \$I_{B} \ll I_{div}\$ – vpetrigo Feb 12 '17 at 11:11
  • I think it's about input impedance/resistance (ie not to decrease it by choosing smaller bias resistors). – Rohat Kılıç Feb 12 '17 at 11:30
  • But this condition \$ Rs = R1||R2 << (\beta+1)R_E \$ is equivalent to this condition \$ I_B<< I_{div} \$ They are the same but they come from the different point of view. Traditional we pick \$ I_{div} = 10..50 I_B \$ . So \$ R1 = (Vcc - V_B)/(11 I_B) \$ and \$ R2 = V_B/(10 I_B)\$ – G36 Feb 12 '17 at 11:59
  • Please edit: \$V_{BE}=0.6 \text{mV}\$ to\$V_{BE}=0.6 \text{V}\$ or \$V_{BE}=600 \text{mV}\$ Basis-Emitter PN – Tom Kuschel Feb 12 '17 at 12:20
The book's approach is an estimation, on the assumption that the base current is negligible - which turns out to be not so great of an assumption here, as you found out.
your approach is more precise, but made the same mistake right here:
The maximum current through the divider without connected load is: Idiv=VccR1+R2=15280⋅103≈54μA
you didn't factor in the equivalent resistance on the base side: at 8.1v @ 10ua, that's equivalent to a 810K resistor (approximately Re * beta - see note below).
So the lower resistor R2 is paralleled by a 810K resistor. Once you factor that in your calculation, it will be alright.
Most people don't take that approach. for example, I typically set the current through R1/R2 to be 10x of the base current. That yielded R1 + R2 = 15v / 100ua = 150K. and go from there for R1/R2 individually. the 10x is picked to make sure that the base current is indeed negligible.
what it shows you is that 1) don't put too much stock in any book; and 2) don't take estimation too seriously. many times, good enough is indeed good enough.
edit:
note: for better approximation, some people would assume that the lower resistor is by-passed by a equivalent resistance of beta * Re -> 750K in this case, vs. 810K the real one calculated earlier. This approach works fairly well as an approximation.
dannyf
  • 4,272
  • Thank you for pointing me out! I've forgotten to take into account the load impedance of emitter follower. – vpetrigo Feb 12 '17 at 18:48
Quote dannyf: "the 10x is picked to make sure that the base current is indeed negligibe."
Yes - of course, correct. However, for a better understanding I like to give some additional explanation.
The background of the commonly applied design criterion (divider current >> base current) is the fact that the ratio Ic/Ib=beta has very large tolerances. That means: For a selected collector current Ic we do not know the actual base current. Hence, we select a design in which the base current (and its large tolerances) play a minor role only.
As a consequence, we have a "relatively" low-resistive voltage divider (if compared with the input resistance at the base node) providing a "stiff" voltage at the base (as "stiff" as reasonable) - nearly independent on beta uncertainties.
(By the way: This works because the collector current is detrmined by the base-emitter voltage and not by the current Ib).
LvW
  • 24,857
  • 52
