I'm trying to run a I2C device using the atmega328p (on a custom board ). I've read the data sheet , and wrote the code "exactly" as show in it: here's the code :
#define F_CPU 1000000
#define SCL_CLOCK 50000
#define BAUD 9600
#define MYUBRR F_CPU/8/BAUD-1
#define TWIMUX 0x1C
#include <avr/io.h>
#include <util/delay.h>
#include <stdio.h>
#include <util/twi.h>
#include <avr/interrupt.h>
// printf to debug
static int uart_putchar(char c, FILE *stream);
static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL,_FDEV_SETUP_WRITE);
// initializing the UART
void init_uart(unsigned short uValue ){
// setting the baud rate
UBRR0H =(unsigned char) ( uValue>> 8); // 0x00
UBRR0L =(unsigned char) uValue; // 0x0C
// enabling TX & RX
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
UCSR0A = (1<<UDRE0)|(1<<U2X0);
UCSR0C = (1 << UCSZ01) | (1 << UCSZ00); // Set frame: 8data, 1 stop
void init_i2c(void ) {
uint8_t twst;
TWSR = 0; // no prescaler
TWBR = ((F_CPU/SCL_CLOCK)-16)/2;
TWCR = (1<<(TWINT))|(1<<TWSTA )|(1<<TWEN);
printf("TWCR 0x%x \n",TWCR);
while(!(TWCR & (1<< TWINT)));
printf(" Start condition has been transmitted \n");
if( (TWSR&0xF8) != TW_START){
printf(" Error \n");
// Setting Address
TWDR = 0x1C;
// cleating TWCR
TWCR = (1<<TWINT) |(1<<TWEN);
if ((TWSR & 0xF8) != TW_MT_SLA_ACK){
printf(" Error at TWSR 0x%x\n", TWSR); // here is the problem !!!!!!!!! TWSR value should be 0x18
return;
if (c == '\n')
uart_putchar('\r', stream);
while ( !( UCSR0A & (1<<UDRE0)) );
UDR0 = c;
return 0;
int main(void)
unsigned short i = 0 ;
// UART init and printf
init_uart(MYUBRR);
stdout = &mystdout;
sei();
init_i2c();
while(1){
return 0;
As you can see in the output I have an error by the TWSR value !
first I tought that the frequency isn't set correctly , but I've measure it and it definitly 50khz. I've measured SDA and SCL and here is the scope pic :
as far as I've learned, both wires should be on high ? I've plugged an arduino board on this chip and it did work fine! so the problem is definitely in the configuration,( my code ).
any idea how might solve this ?
thanks in advance !
