I've managed to blow a capacitor while doing maintenance on my 1967 electric organ. It's a 80uf 25V. I've done some searching and found that I can replace it with one that has a higher voltage rating but the same farad value. Is there anything else that I need to know before I buy a replacement? I've read some things about ripple current and resistance? The numbers on the capacitor are: B41283-s5806-z2 80uf 25V A 0-507-24 W9
ThreePhaseEel
  • 8,858
  • 26
  • 41
Creeker
  • 63
A 80µF electrolytic capacitor from 1967 could be easily 120uF back then, and 40µF today. It probably had a much higher internal resistance than modern capacitors. I think any good quality 100µF 25V is okay. You may of course use 100µF 35V or higher voltage. If you still prefer 80µF, that is okay, but I really think that 80µF or 100µF does not matter.
Do you know how old tube radios are repaired ? Every capacitor is cut away and replaced, without testing them if they are bad or still a little okay.
Jot
  • 353
Very likely any 80 µF capacitor you can find today rated at 25 V or more will work fine in this situation. Such a capacitor from 1967 is electrolytic, so already polarized. Replacing it with a 80 µF 35 V, for example, modern capacitor should no result in any problems.
Olin Lathrop
  • 310,974
  • 428
  • 915
    EE in training, here. Isn't it true that electrolytic perform better around their rated voltage? So he should go with a 25V? – Brian Dohler Jan 28 '17 at 22:48
    no always better to have at least 20% margin higher V ratings also tend to have lower ESR – Tony Stewart EE75 Jan 28 '17 at 22:56
    @BrianDohler, I remember being told that electrolytics should have at least 10% of rated voltage across them but I couldn't find much to back that up when I once read around. So I'd say putting a 35V in should be fine. – TonyM Jan 28 '17 at 22:59
  • Thanks guys. I'm not sure where I heard that and I couldn't find anything to back it up either. – Brian Dohler Jan 28 '17 at 23:04
  • Awesome, thanks guys! Any idea where I could purchase one from? The places I found will only sell 50 or 100 at a time – Creeker Jan 28 '17 at 23:33
    @TonyM: There is some truth to what you say. Keeping some voltage on electrolytics helps preserve the oxide layer that is the dielectric. It's not much of a issue with modern capacitors, though. I only mentioned 35 V since that's a common voltage today. I would expect a 25 V cap to already be derated properly in the original design. Changing from 25 to 35 V really shouldn't be any issue. It's not a large change – Olin Lathrop Jan 28 '17 at 23:50
  • @Creek: There are plenty of distributors that sell small quantities. Check out Mouser as one example. – Olin Lathrop Jan 28 '17 at 23:56
  • @OlinLathrop, yes I think you're right and I forgot to say earlier that I've always tried to keep at least 50% of the rated voltage on a smoothing/decoupling electrolytic. – TonyM Jan 28 '17 at 23:56
