12
I'm having some capacitors blown up and I am not sure what's the cause of this. It is definitely NOT OVERVOLTAGE and NOT in WRONG POLARIZATION. Let me introduce the scenario:
I have designed a double cascaded Boost converter using this scheme:
Cascaded Boost Converter
Vout can be obtained from: \$\ Vout=Vin/(1-D_\max)^2\$ where \$D_ \max\$ is the maximum duty cycle.
I want to step-up an input voltage of 12V into a 100V output voltage. My load is 100Ω, hence it would be dissipating 100W. If I consider no losses (I know I'm being TOO idealist, calm down), the input voltage source will deliver 8.33A
We can split the circuit into two stages, the first stage's ouput is the second stage's input. Here comes my problem:
C1 is blowing up when the voltage accross it reaches aproximately 30V. C1 is rated for 350V and it's a 22uF electrolytic capacitor (radial) 10x12.5mm. I am totally sure the polarization is right.
The second stage's input current should (ideally) be around 3.33A (in order to keep the 100W with 30V for this stage). I know the current might be higher, but it's a good aproximation for this purpose. The switching frequency is 100Khz.
For some reason the cap blows up and I don't really know why. Of course that when this happens the cap (dead) is hot.
May it be an effect of the ESR? This cap has a 0.15 Dissipation Factor at 1kHz. \$|X_c|= 1/(2*pi*100Khz*22uF) =0.07234Ω \$
So \$ESR=0.15*0.07234= 0.01Ω\$ (DF would also increase for a higher frequency) for C1.
Since L2 is pretty large, I would expect C1 to deliver a pretty constant current equal to the second stange's input current (3.33A) so the power dissipated in ESR is supposed to be around: \$3.33A^2 * 0.01Ω = 0.11W\$
Can this make it too hot and explode? I doubt it....
Additional information:
  • L1 is about 1mHy
  • L2 is about 2mHy
  • D1 is a schottky 45V diode
  • I tried two different capacitors: 160V 22uF that blown up, and then I tried the 350V 22uF which also blown up.
  • Measuring the current in the cap would be difficult due to PCB layout
  • Both the first and second MOSFET has a small snubber RC network. I don't think it could cause any problem in C1.
I am waiting for your ideas!
EDIT n°1= L1 is pretty large, ripple is only 1% of the rated input current (let's say 100W/12V = 8.33A) so que can assume it's almost like a constant current at the input of stage 1. For stage 2 inductor current ripple is less than 5%, we can also think it's a constant current). When MOSFET 1 is turned ON, around 8.33A goes through it, but when it's turned off, that current (we said "practically constant") would go through D1. We can say current in the capacitor would be \$ I_{D1} - I_{L2} \$ . Then we finally find that the peak current in C1 must be in the order of \$ 8.33A - 3.33A = 5A\$. Pretty much current! and it would dissipate \$5A^2 *0.01Ω = 0.25W \$ ... but looks not so much power dissipated in the ESR.
As someone said, I might also consider the internal inductance of the cap, but i think this wouldn't be a cause of power dissipation (we know inductors store energy but don't make it into heat) Anyways, despite of the calculation above was very simplified and it might be a little higher power dissipated, I still wonder if it's enough to make it boil and explode!
KenshinARG
  • 121
    What do your waveforms look like? – W5VO Jan 28 '17 at 02:52
    Have you probed the voltage across the capacitor with an oscilloscope? I'm betting you're getting large voltage spikes due to the inductors that you can't see with a regular meter – DerStrom8 Jan 28 '17 at 02:52
  • @W5VO you beat me to it by 20 seconds =P – DerStrom8 Jan 28 '17 at 02:53
    Well, since you have absolute proof that it's not voltage or polarity, the only thing left is ripple current. – gbarry Jan 28 '17 at 02:54
  • @DerStrom8 I did measure the capacitor with an oscilloscope. I don't have photos because it was an analog scope (i don't have enough hands!) but **at first sight** the voltage seemed pretty constant. By the way, how big that spike could be in this topology? I think the capacitor would "impose" a voltage to the inductor when the MOSFET n°2 is turned on. If not, I would expect D1 to be destroyect much sooner than the cap because it only resists 45V vs. 350V of the Capacitor.... – KenshinARG Jan 28 '17 at 03:01
  • @gbarry If you mean the same ripple current that goes through L2, then it is only 10% of the rated current (0.1*3.33A = 0.33A) which would dissipate a very low power on ESR+C1's reactance (where else?...) I hope I am mistaken and you are right... – KenshinARG Jan 28 '17 at 03:10
    Approximately, you are turning 10V into 100V (with diode and other losses). (1-D)^2=0.1 => D=0.68. The L1 discharge period is (1-D)=0.32, therefore current through D1 to C1 alternate between 0A and 3.3/0.32 = 10A. I looked up a ripple current rating of a typical 22uF 350V aluminum cap, it is 0.35A. – rioraxe Jan 28 '17 at 05:02
  • What is ratio of Ripple current to rated value? 50% ? 150%? – Tony Stewart EE75 Jan 28 '17 at 05:39
    When you choose a 350 V capacitor instead of 50 V, you end up with low capacitance, high ESR and low ripple rating. Simulate/calculate it and you will see how much rating you need. Also, what is the reason for a two stage approach? – winny Jan 28 '17 at 08:16
  • What is the overall efficiency of your cascaded boost DCDC convertor? If it falls short of your expectations then you are wasting energy in the caps and heating them up . – Autistic Jan 28 '17 at 11:13
  • Link to the datasheet for C1. We need to see the small print. –  Jan 28 '17 at 11:34
  • How quickly do the capacitors blow up? What is the timescale here? Milliseconds, seconds, minutes, hours, or days? – Peter Mortensen Jan 28 '17 at 15:22
  • @rioraxe Part of that current will go to the load (stage 2) and the input voltage is 12V (falls from 12,7V to 12,2~12.0V with 8A) So, D is 0.653. This leads to 34.6V at the input of stage 2, and input current of 100W/34.6V = 2.89A. Then the Ouput current of stage 1 must be 2.89A/(1-0.653) = 8.33A. This means the cap would be only absorving 8.33 - 2.89A = 5.44A (almost half the current you said). I am not convinced of the way you reached that value (10A), but I will be pleased to know your point of view with more detail (I'm not so confident of my statements either) Thanks! (See my edit n°1) – KenshinARG Jan 28 '17 at 16:15
  • @TonyStewart.EEsince'75 Ripple current in L1 should be around 1% according to (Vin x Dmax)/(Fs x L1 x Iin) (Equation 18 from this [application report](http://www.ti.com/lit/an/slva372c/slva372c.pdf) ) – KenshinARG Jan 28 '17 at 16:24
  • @winny I would need 88% duty cycle to step up this voltage with one stage. This cascaded boost is a prototype for a boost converter that will step up from 24V to 350V; 1 stage converter would need 93% duty cycle which is pretty high. So I decided to make it cascaded to add some "relief" – KenshinARG Jan 28 '17 at 16:29
  • @Autistic I didn't measure the efficiency yet because i didn't reach the 100V output goal! Anyways, if the cap is causing, let's suppose, 2W loss, it wouldn't be a critical efficiency loss BUT a big power for a small cap.... – KenshinARG Jan 28 '17 at 16:41
  • @BrianDrummond This was the little boy [226CKE160MLN](http://www.mouser.com/ds/2/88/ckh_cke-611140.pdf) – KenshinARG Jan 28 '17 at 16:44
  • You seem to have given it though which is good and my opinion is slightly off topic here but 88 % isn't too bad. Transformer could be considered too. – winny Jan 28 '17 at 20:30
  • @KenshinARG I just rounded the number to 10 times input to output, nevertheless that is closer to reality then assuming 100% efficiency as with your calculation. As for the ripple current, coming in alternating between 0A and 10A, going out average to 3.3A. You can do this, 0A - 3.3A vs 10A - 3.3A, the current step is still 10A. – rioraxe Jan 28 '17 at 20:45
  • By the way, your calculation concentrated on the failure mode due to ripple current being the average heating due to ESR estimated from the spec. With the ripple current so far out of spec, is the spec ESR still valid? Is average heating the failure mode? I don't know, but I wouldn't assume either but this, the ripple current is 20 times or more the rated limit. – rioraxe Jan 28 '17 at 23:27
  • @KenshinARG you mean the one with 92mA ripple current rating on page 4 of that datasheet? –  Jan 29 '17 at 15:23
  • @rioraxe I'm pretty sure the heating problem originates in ESR. Anyways, the ripple current is below 83mA (L1 ensures that), average current is high, ripple current is not. Additionally, the value in the datasheet is rated for 120Hz, the value decreses with frequency till the self resonant frequency and then rises due to ESL. It's not a reliable idea to use these values for 100kHz. I would need ESL to make a good calculation of the real dissipation factor at 100kHz but it's not available in the datasheet. But I repeat: It must be ESR, I will test the circuit using ceramic caps tomorrow. – KenshinARG Jan 30 '17 at 00:28
  • @BrianDrummond exactly, that ugly cheap thing... – KenshinARG Jan 30 '17 at 00:31
The peak ripple current for C1 is approximately I(out)/D where D= duty cycle. If the Duty cycle is say 50% at your 30 V output then the ripple for C1 is 3.3/0.5 = 6.6 A. As the duty cycle is reduced this gets worse. If the duty cycle was 10% = 0.1 then the current peak is 33 A.
If you then use your ESR value the power dissipated is about 0.4 W, much higher than you previously calculated.
If I look at 160 V capacitors on Mouser (I'm assuming you are using Al Electrolytics) then I see nothing generally available that could sustain the peak currents you need.
I'd suggest you use TI's Webench to work through a design and then look at the selected components. You will notice on many of the designs they use very low ESR capacitors and often have two or even three in parallel. For example they use Panasonic polymer caps often in the designs and they have very high ripple current ratings at very high frequencies.
Jack Creasey
  • 21,428
  • Hi Jack, please check out my EDIT n°1. We differ a little in our calculation but we are aiming to the same thing. By the way, you said "*As the duty cycle is reduced this gets worse.*" but your formula above says the opposite. – KenshinARG Jan 28 '17 at 16:49
  • Your right...... It's simply D in the approximation and not 1-D. – Jack Creasey Jan 28 '17 at 16:59
Your capacitors may have quite big internal inductance - too much for 100 kHz pulses. You should connect some smaller non-electrolytic capacitors in parallel with them until the oscilloscope shows that the voltage limits are not exceeded.
BTW. the current rushes as pulses from the inductors as soon as the fets turn off. The start of the current pulse is very sharp - as sharp as how fast the fets can turn off. If the switching frequency is 100 kHz, the capacitors really should handle several MHz properly. NOTE: low inductance electrolytes for SMPS applications are developed but they cost some real money, not pennies as the ordinary models.
Late addition: All your output power is at first stored in the capacitors - no direct way from the input to the output. As suggested in several othe comments - the sheer dissipation in your capacitors may cause some boiling. The inductance causes it to localize more at the near ends of the inside plate roll.
I bet on power created by ripple currents. Your capacitor has some ESR. Pulsed current of your magnitude may leave there like ten-twenty watts quite easily. So... Put several in parallel, with lowest possible ESR/ESL
  • My plan now is using several parallel Polyester film capacitors, I think they have lower ESR and can resist the voltage I need, avoiding dozens of ceramic caps. How do you think? – KenshinARG Jan 28 '17 at 16:58
    I don't understand why you avoid ceramics. I once used array of 100 ceramic caps, was perfect. Different application, but still.. –  Jan 28 '17 at 17:00
  • By the way, best thing about SMT ceramic caps is that you can stack even four layers of them. –  Jan 28 '17 at 17:01
  • Just because of cost and size (of the array) this design is a prototype for a bigger converter. I would need too many. I will end up doing it if I can't make it work with the Polyester ones! – KenshinARG Jan 28 '17 at 17:04
  • My strategy is usually to take best performance option and optimeze on next stage. In your place i would start with ceramics, or even both options. –  Jan 28 '17 at 17:21
Cap                       Max ESR Ω   Max RMS ripple
(uF)   VDC  PART #        120Hz      (mA) 120Hz,105C  DxL (mm)
22     160  226CKE160MLN  11.3094     92              10x12.5
C*ESR=Ts=22uF*11.3 Ω = 250us , f(bw) =0.35/Ts = 5.6kHz which is the fastest rate of charging it can handle and reach full charge voltage.
f switch = 100kHz PWM variable D thus as 100kHz it will appear as a lossy resistor only at 11.3 Ω with losses of \$Pc=I^2ESR\$ and a rated ripple current of 92mA the device can only handle 1.03W at max temp of 105C or a rise of 85C above room temp 20C.
Now to choose a 22uF cap, you want to follow the App Note recommendation and choose a low ESR cap and not a general purpose electrolytic ( G.P. e-cap)
What they don't tell you in school, ( and I have commented many times on this site) is that an G.P. e-cap has a ESR*C >= 100 us while a low ESR cap < 10us and best case < 1us. This is what you need when choosing a switch period < 10us.
Now it is not hard to sort Digikey or Mouser databases by ESR or search in other ways for ultra low ESR. You might also want to read the MSDS datasheets of e-caps for toxic material exposure when they blow up.
The App Note advises you to expect under INDUCTOR SELECTION that
A good estimation for the inductor ripple current is 20% to 40% of the output current.
E-Caps are rated in several ways. D.F. @120Hz ( for small line bridge rectifier use) max ripple current ESR (typ.) not aged after 10 yrs !
It is important to remember that Caps are usually charged by dumping current pulses then discharged slowly between pulses, so the duty cycle determines the ratio of Peak/Avg current. If the ripple voltage is 10% then the pk/avg current ratio is 10/1. If the energy dissipation is the power dissipation in each pulse times the pulse repetition rate. No problem as 100Hz and 1000x worse at 100kHz.
Hence the result of not understanding subtle advice in the App Note ... is a Chinese fire-cracker.
Refs from OP in comments that should have been in Question
  • With this frequency I should have chosen a low ESR capacitor, my bad. I like your point of view from the time constant but I'm afraid to say that ESR decreases with frequency. This graph from Murata shows the [ESR curve](http://www.murata.com/~/media/webrenewal/products/emiconfun/capacitor/2013/02/14/en-20130214-p1/en-20130214-p1_img0003.ashx?la=en&h=300&w=427) dependancy over frequency. I didn't take into account ESL (I don't have it) but if you use that way to estimate the ESR, ***at 120Hz*** you will obtain 9Ω. I do believe ESR is blowing it up, but i think those 11.3Ω doesn't apply here. – KenshinARG Jan 28 '17 at 20:08
    @KenshinARG Note Murata curve for ESR only rises above series resonance.. Always remember the ESR C time constant for different types of caps or read my other links – Tony Stewart EE75 Jan 28 '17 at 20:11
  • I think you have a good idea of how to calculate the thermal dissipation capability of the capacitor using the ESR and ripple current provided at 120Hz. How did you calculted those 1.03W? – KenshinARG Jan 28 '17 at 20:11
  • spec I ripple^2*ESR=Pc .. 1 watt for this size is large as dielectrics are also thermal insulators – Tony Stewart EE75 Jan 28 '17 at 20:13
    You must shunt E-caps with low ESR ceramic caps like X5R as they suggest which is around T=0.01 to 0.1us range depending on ceramic family – Tony Stewart EE75 Jan 28 '17 at 20:15
  • I ripple^2*ESR = (0.092A)^2*11.3094Ω = **95mW** (This might make my power loss calculations to justify why it explodes) If I use a Cereamic cap in parallel with this one, can the problem be solved? I would expect the equivalent ESR to drop below the ceramic's ESR with a parallel connection but I'm not sure (these are not just resistors) – KenshinARG Jan 28 '17 at 20:22
  • You may need several .. 1uF & 0.1uF x N to reduce ESR and distribute the current. but you must change the 22uF to 100 mOhm or less – Tony Stewart EE75 Jan 28 '17 at 21:20
Note that there is capacitors for FILTERING ... And there is capacitors for DECOUPLING.
The capacitors for FILTERING are specified for a RMS current. This specification is printed on the capacitor. So if not printed, don't use as filtering.
There are also capacitors for filtering at "high frequencies" (in high frequency converters --> possibly > 10 MHz). These capacitors have a resonnant frequency as high as possible ... which lead to a residual very low inductance, wiring is critical.
