I want to make bridge rectifiers for some toy field phones so that the wires that connect one phone to the other will work regardless of polarity.
I was wondering if Schottky diodes would be the best option because of there low forward voltage drop?
But I don’t know if the higher reverse leakage of a schottky would be detrimental to proper function.
6v dc (from AA batteries) would be the maximum voltage involved.
If they are what would be a particular diode with the lowest forward voltage drop?
Thanks.
retspag
Schottky diodes are best used for fast switching application and where the voltage drop due to diode needs to be as less as possible. Disadvantage is the high reverse leakage current (and the current is temperature dependent) and lower reverse breakdown voltages.
If your project is battery operated only and need to save each bit and byte of energy for long term, then opting for normal diode with least reverse leakage current will be better choice.
Also other factors such as price may factor. Schottky diodes are expensive. So, its a trade off among reverse voltage rating, speed, leakage current and price. So, for your case I would really see further down on the requirement of minimum battery voltage needed for the circuit to operate and battery life time expected. Only, then a good decision can be made.
Also, if space is not a constraint, opting for PMOSFET as blocking diodes (even NMOS will do) also help in getting out all the juice off battery to the circuit as the forward drop of FETs will be in a few 10s of mV typically.
Using a diode to ensure current flows in only one direction, without causing a voltage drop
User323693
  • 9,151
  • 50
Probably. A typical 6V dry cell battery has useful capacity down to ~4V (1V per cell) and your telephones are probably designed to work down to this voltage only (if they could use a lower voltage then why have 4 cells?).
A silicon bridge rectifier drops ~1.4V (about the same as having one flat cell) which may significantly reduce the operating time. A Schottky bridge drops ~0.8V.
Here's an example 6V AA discharge graph. I have copied the original curve to show what you would get with 0.8V and 1.4V drop through the rectifier. In this example (80mA average current draw) the ~12 hours run time is reduced to ~7.5 hours with a Schottky bridge and 2 hours with a silicon bridge.
In practice it might not be quite this bad because the current draw will probably be less at lower voltage, but you get the idea.
High leakage is generally only a problem if the diode is rated for much higher current than needed or is being operated at high temperature. Leakage current also increases as voltage approaches the diode's rating, so choose a rectifier that has much higher voltage rating than needed but not much higher current, eg. 1A 30V rather than 3A 10V.
Finally, consider the current draw of your phones. If it is much higher than the leakage current (likely) then it shouldn't be a problem. A higher current diode may have lower voltage drop which is more important.
Bruce Abbott
  • 55,540
  • 47
  • 89
  • The lowest I can find is 1A 20V. will the voltage drop of all Schottky diodes witch are 1A 20V be about the same or will it vary by model? one more question how would a germanium diode compare for the application? thanks – retspag Jan 24 '17 at 06:44
  • You would have to compare datasheets to be sure, but different diodes with the same ratings usually have similar voltage drop. High current Germanium diodes have very low voltage drop, but also high leakage. Point-contact diodes are only good for low current. – Bruce Abbott Jan 24 '17 at 19:49
  • Thanks, I think you told me everything I needed to know to make my decision. – retspag Jan 25 '17 at 05:37
When you say best, what do you mean? Cheapest, best performance, easiest? Usually it's a balance of things. Shottky is cool if only need simplicity. Otherwise you need more complex circuit.
  • Cost doesn't matter, all these components are so cheap cost is negligible so what if a diode costs 15 cents instead of 3 cents. I want the best functioning diode for a low voltage bridge rectifier. I know there's other ways of doing it I just want to use a rectifier. – retspag Jan 24 '17 at 23:33
  • You don't understand. There are more expensive and more efficient solutions. –  Jan 25 '17 at 03:16
  • Ok, what's a more efficient solution regardless of price. thanks – retspag Jan 26 '17 at 01:33
  • MOSFETs controlled by some electronics. Linear technologies has integrated solutions, but you can make it even better by your own. –  Jan 26 '17 at 05:18
  • Thanks, I might look into that sometime in the future, I'm quite an amateur at all this so I'll stick with a simple solution for now. – retspag Jan 27 '17 at 05:09
