I have configured timer 4 for PWM with following code and connected LED to the configured pin. It is working.
TIM_TimeBaseInitTypeDef TIM_BaseStruct;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);    // Enable bus clock
TIM_BaseStruct.TIM_Prescaler = 0;   // Set prescaler (frequency divider)
TIM_BaseStruct.TIM_CounterMode = TIM_CounterMode_CenterAligned1;    // Set counting mode (up, down, center-aligned) to center aligned for better motor control
TIM_BaseStruct.TIM_Period = 4000; // Set timer period (timer reset/change direction value)
TIM_BaseStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_BaseStruct.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM4, &TIM_BaseStruct);    // Initialize timer with chosen settings
TIM_Cmd(TIM4, ENABLE);  // Start timer
GPIO_InitTypeDef GPIO_InitStruct;
/* Clock for GPIOD */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
/* Alternating functions for pins */
GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4);
/* Set pins */
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_12;
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_Init(GPIOD, &GPIO_InitStruct);
TIM_OCInitTypeDef TIM_OCStruct;
TIM_OCStruct.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCStruct.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCStruct.TIM_OCIdleState = TIM_OCIdleState_Reset;
TIM_OCStruct.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCStruct.TIM_Pulse = 1999;
TIM_OC1Init(TIM4, &TIM_OCStruct);
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
but when I configured TIM 1 and connected LED to its pin, nothing happened (I tested pin separately by toggling it as output to make sure I connected LED to the right pin and it lit up)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);    // Enable bus clock
TIM_BaseStruct.TIM_Prescaler = 1;   // Set prescaler (frequency divider)
TIM_TimeBaseInit(TIM1, &TIM_BaseStruct);    // Initialize timer with chosen settings
TIM_Cmd(TIM1, ENABLE);  // Start timer
/* Clock for GPIOE */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_TIM1);
/* Set pins */
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_9;
GPIO_Init(GPIOE, &GPIO_InitStruct);
TIM_OC1Init(TIM1, &TIM_OCStruct);
TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
Is there something different I have to do about advanced timers to make them work with pwm? I also achieved success with TIM3 and TIM12 (which are general purpose timers), but not with TIM8 (which is also an advanced timer).
Bence Kaulics
  • 6,353
  • 60
Terraviper-5
  • 191
With help from people on STM32 forum, I found out I was missing the following additional code to make advanced timer work the same way as general-purpose timer:
TIM_BDTRInitTypeDef TIM_BDTRInitStruct;
TIM_BDTRStructInit(&TIM_BDTRInitStruct);
TIM_BDTRConfig(TIM1, &TIM_BDTRInitStruct);
TIM_CCPreloadControl(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
Note: Channels must be initialized before calling the code for advanced features. If you try to initialize channels after that there might be problems (my LED connected to channel 3, which was initialized after advanced features, was always ON and did not respond to pwm changes, oddly channel 4 was working but was also initialized after advanced features).
Terraviper-5
  • 191
This is an old question but I have a general comment about your code as it might cause bugs (I came across this bug just today, preventing me to use the PWM at all). I am posting it as an answer because I can't use comments yet with my new account.
When using init structs, it is best practise to call their corresponding struct init functions before doing anything else, e.g. here TIM_TimeBaseStructInit() for TIM_TimeBaseInitTypeDef, GPIO_StructInit() for GPIO_InitTypeDef and TIM_OCStructInit() for TIM_OCInitTypeDef.
An uninitialised structure member can trigger unexpected behaviour. In your code, you didn't initialise all members of TIM_OCStruct, which means TIM_OC1Init() will use dirty values to init the timer registers. You should either call TIM_OCStructInit() or set all members individually.
fripon
