I got a flash for my DSLR camera: A mecablitz 52 AF-1 digital Canon with multi-language manual from here.
In section 15.2 (page 187 for english), it states:
15.2 Conditioning the flash capacitor
The flash capacitor built into the flash unit undergoes a physical change when the device has not been used for a long time. For this reason it is necessary to switch the device every three months for approx. 10 mins. The power supplies must deliver enough power so that flash standby lights up no later than 1 min after switching on.
I'm wondering: What physical change could a capacitor undergo, which can be more or less avoided by charging it every three months?
sweber
  • 8,580
  • 35
    See http://electronics.stackexchange.com/questions/50390/amplifier-capacitors/50392#50392 –  Dec 31 '16 at 14:27
    It does not say specifically, but section 2.4.2 is a start: http://www.nichicon.co.jp/english/products/pdf/aluminum.pdf This oxie layer takes time and current to build up if the capacitor has not been in use for a long time. – winny Dec 31 '16 at 15:02
Even when not in use, there are chemical reactions going on bettween the anode oxide layer and the electrolyte. This may increase leakage current and reduce withstand voltage over time.
This effect however is reversable by performing a so called "voltage treatment" (also "conditioning").
Voltage treatment normally involves applying the rated voltage with a resistor in series to the capacitor for a extended period (say 1 hour). This reforms the dielectric.
Rev
  • 10,017
  • 40
  • 77
