Below is an NPN transistor symbol and the voltages at its terminals are Vb, Vc and Ve with respect to the ground:
I read that: during the saturation the Vce = (Vc-Ve) settles to around 0.2V and the further increase in base current will not make Vce zero.
But why doesn't Vce become zero?
As far as I know: when the transistor is saturated, the base-collector junction turns on, like a diode, so the collector voltage will follow the base voltage increase, only it will be a diode-drop below. But the same thing happens between the base voltage and the emitter voltage. So at saturation and beyond one can write the following(?):
Let's call the diode drop as Vd between p and n junctions, so the collector and the emitter voltages can be re-written in terms of the base voltage as:
Vc = Vb- Vd
Ve = Vb -Vd
Vce = Vc -Ve = 0
Where am I wrong here?
user16307
  • 11,802
  • 51
  • 173
  • 312
  • Vce becomes zero when the collector current becomes zero, but that is usually not a useful state. – CL. Dec 21 '16 at 09:24
  • ?? the collector current becomes zero in cut-off mode not in saturation, isn't it? – user16307 Dec 21 '16 at 09:26
  • If the base/collector junction turned on like a diode, which way would the current flow? – CL. Dec 21 '16 at 09:31
  • Yes, zero current is cutoff. But you can make Vce arbitrarily small by making the collector current small enough. But in practice, you want to switch a certain, fixed current. – CL. Dec 21 '16 at 09:34
  • Current flows from higher to lower voltages. – CL. Dec 21 '16 at 09:36
  • oh ok so you are saying if Vce were zero that would be like a cut off situation no current would flow from Vc to Ve. But do you know why is there a difference? is it designed in silicon level such that the voltage drop between Vb and Vc is less than the drop between Vb and Ve? so maybe they deliberately do this not to cause zero Vce? – user16307 Dec 21 '16 at 09:40
  • I think Im a little confused in current directions here. In saturation Vb>Ve and Vb>Vc. So where will the base current flow into in this case? Towards both Vc and Ve? So part of Ib flows against the Ic in that case? – user16307 Dec 21 '16 at 09:55
  • In most situations, the base/collector junction does not behave as a diode. – CL. Dec 21 '16 at 22:29
The transistor going into saturation isn't a property of the transistor itself, but instead a property of the circuit surrounding the transistor and the transistor, as part of it.
The simplest case to imagine is an NPN switch. I'll present two different such switch circuits to make the above point concretely clear:
Let's assume a perfect \$\beta=100\$ in both cases shown. We are going to increase the current source's current into the base (of either or both NPNs) from \$0\:\mu\textrm{A}\$ to \$100\:\mu\textrm{A}\$. In both cases, the relationship of \$I_C=\beta\cdot I_B=100\cdot I_B\$ will be considered to hold until some other limitation forces this relationship to change.
In the left circuit, as the base current rises, the permitted collector current also rises. When \$I_B=90\:\mu\textrm{A}\$, then \$I_C=9\:\textrm{mA}\$ and the voltage drop across \$R_1\$ will be \$I_C\cdot R_1=9\:\textrm{mA}\cdot 1\:\textrm{k}\Omega=9\:\textrm{V}\$. This works fine, as the collector voltage will then be \$V_C=10\:\textrm{V}-I_C\cdot R_1=1\:\textrm{V}\$. This voltage is between the ground rail of \$0\:\textrm{V}\$ and the power supply rail of \$10\:\textrm{V}\$ and since the transistor isn't yet in saturation, as I still expect \$V_C\ge V_B\$ (given \$V_E=0\:\textrm{V}\$.) But as \$I_B\$ increases still further towards \$I_B=100\:\mu\textrm{A}\$, I would expect the collector voltage to drop still further to a final case where \$V_C=0\:\textrm{V}\$ as the voltage drop across \$R_1\$ reaches a full \$10\:\textrm{V}\$. This assumes that the collector actually can achieve such a situation. But it can't. But before discussing why, let's move to the right side.
Looking at the right side schematic, you see the same thing except that \$R_2=10\:\textrm{k}\Omega\$, instead. Other details remain the same. In this case, though, the voltage drop across \$R_2\$ will reach \$9\:\textrm{V}\$ when \$I_B=9\:\mu\textrm{A}\$ and \$I_C=900\:\mu\textrm{A}\$ and a full \$10\:\textrm{V}\$ voltage drop when \$I_B=10\:\mu\textrm{A}\$. Assuming this is even possible, what should then happen as the \$I_2\$ current source increases still further?
Well... nothing more can happen. There's no possible way for a still larger voltage drop across the collector resistor, \$R_2\$. To do so would require \$Q_2\$'s collector to move into a negative voltage value with respect to ground. But there are no sources for that negative voltage available and while \$Q_2\$'s guts might be able to produce voltages in between \$0\:\textrm{V}\$ and \$10\:\textrm{V}\$, \$Q_2\$'s guts can't manufacture voltages outside that range out of thin air. It just doesn't happen.
So the process stops here. More base current achieves nothing. You can apply it, of course. There's nothing to stop \$I_2\$ from continuing right on up to a full \$100\:\mu\textrm{A}\$. So that works just fine. But the collector voltage just cannot continue it's downward direction any more. So the collector current just stops, regardless of the base current. The result is that the effective \$\beta\$ drops from 100 to some lower value, then.
All this said, though, a real BJT can't even cause the collector voltage to match up exactly with its emitter voltage. The base-collector diode can go into a forward biased mode in order to allow the collector to drop. And it has to do that, if it is going to squeeze out the last remaining additional dribbles of collector current so that the voltage drop across the collector resistor can rise just a little bit more. But at some point before the collector voltage reaches the emitter voltage, the process halts. There must be at least a small voltage difference remaining, just to operate at all. This might cause the base-emitter diode to be forward biased with \$800\:\textrm{mV}\$ while the base-collector diode is forward biased with \$600\:\textrm{mV}\$, so that \$V_{CE}=200\:\textrm{mV}\$. But the base-collector diode cannot be more forward biased than the base-emitter diode. Because doing so would require the BJT to present an impossible collector voltage that it cannot observe and cannot just create out of thin air. (At least, in the circuits I've shown above.)
At this point, it should also be clear that the external circuit matters. These two circuits were identical except for the collector load. But the limitation of collector current depends upon the collector resistor value, as well as the BJT. So saturation is best not seen as just an internal detail of the BJT but instead that it also depends upon what is surrounding the BJT.
Another way of saying this is that the transistor enters gradually into saturation as the collector current, coupled with the collector load external to it, causes the collector voltage to move in such a way that the base-collector diode transitions from being reverse-biased into becoming forward-biased. While the BC junction is still reverse-biased, the transistor is in active mode. Once the BC junction transitions into forward-biased, the BJT is in saturated mode. However, saturation is gradual in the sense that \$\beta\$ gradually declines and doesn't suddenly change (it's not a switch-like effect) -- in the above examples where the base current is gradually changed.
For design purposes, if you want a switch behavior then you anticipate the above process and just design around some value of \$\beta\$ that you want to achieve for your switch. If you look it up on a datasheet, there will usually be a curve showing just how small of a difference between the collector and emitter is achievable given some desired \$\beta\$. Or, at least, an example for \$\beta=10\$ which is usually considered to be a highly saturated case for most (but not all) BJTs. Since the external circuit can be designed to force a low \$\beta\$ result, that all works fine. (Of course, you still have to keep in mind dissipation and other limitations for the BJT.)
Hopefully, that helps.
jonk
  • 77,059
  • 73
  • 185
  • great answer, but I still don't understand this: "The base-collector diode can go into a forward biased mode in order to allow the collector to drop. And it has to do that, if it is going to squeeze out the last remaining additional dribbles of collector current so that the voltage drop across the collector resistor can rise just a little bit more"...Could you explain more about this? – Dat Sep 01 '21 at 08:26
  • @Dat Yeah. That could be written better. Once the collector has gone into saturation (forward-biased with respect to the base), there's not much voltage room left between it and the emitter. (A few hundredths of a volt is all that there is left for the collector to move, at most.) So as the collector pinches towards the emitter still further, the barely increased voltage drop across the collector load can only slightly increase in current. That's the "dribbles" part. So if you go from 9.4 V across R2 to 9.8 V across R2, it's not going to make much difference in the current in R2. – jonk Sep 01 '21 at 17:25
  • I understand that Vc cannot go below 0 volt, but I still don't understand why it cannot be 0 volt = Ve. You said: "But at some point before the collector voltage reaches the emitter voltage, the process halts. There must be at least a small voltage difference remaining, just to operate at all." Opertate what?? – Dat Sep 01 '21 at 18:08
  • @Dat Remove the "just to operate at all" part. Forget the parenthetical, if it is getting in your way. I was speaking in hyperbole. It's not important. Just accept that the collector cannot actually reach the emitter voltage. But it can get close (if there is sufficient base current to support it.) – jonk Sep 01 '21 at 18:11
  • it just clicks in my brain what saturation of BJT is. One more dumb question: I thought the collector-base transistor of BJT is always reversed-biased even in saturation mode, because the \$I_C\$ always goes down to the emitter (I mean the \$I_C\$ always goes reversed in collector-base transistor). So why do you call it forward-biased in saturation mode? Is it called so just because Ve >Vc, regardless the direction of \$I_C\$ ??? – Dat Sep 02 '21 at 02:58
  • @Dat No. Saturation is ***defined*** as the moment when the BC junction becomes forward-biased. You can think of this as the base being forced to drive now ***two*** diodes, instead of just one. The base is driving the usual BE forward-biased junction, but is then also supplying current ***into*** the collector, which then passes through to the emitter ***as if*** it were collector current. That may help visualize it. I just had a discussion when one of the top engineers on this site about this, where they didn't realize this could happen like that (current mirror issue.) – jonk Sep 02 '21 at 04:13
  • A typo in my above comment, it is "Vb > Vc", not "Ve > Vc"....but how do you define forward-biased state of BC junction? How does current goes from the base to supply into collector, then goes down to the emitter? It is so strange to hear these. – Dat Sep 02 '21 at 04:39
  • Let us [continue this discussion in chat](https://chat.stackexchange.com/rooms/129189/discussion-between-jonk-and-dat). – jonk Sep 02 '21 at 04:41
The very simplistic theory is fine. However, the practice is more complicated, a transistor is not two ideal, isolated diodes.
Amongst the details, we have the residual resistance of the diodes, the way forward bias changes the effective barrier heights in saturation, charge spreading, making the simple NPN scheme work as a useful transistor involves a lot of technology.
Given that the forward voltage of the junction is 0.7v, a VCEsat of 0.2v is 'about zero'. Measure a few different types of transistor at a few currents, you'll see quite a spread from 0.2v depending on the conditions.
You can buy transistors that have been designed to have a very low VCEsat. IIRC, some Zetek parts have a very low VCEsat.
Neil_UK
  • 158,152
  • 173
  • 387
  • Is the reason: the voltage drop between Vb and Vc is less than the drop between Vb and Ve? Or something else? – user16307 Dec 21 '16 at 09:29
    It depends what you mean by reason. If VCE != 0, then Vbc != Vbe. Which came first? The two diodes have different doping profiles, areas, detailed connections, I would guess most people would cite that as the 'reason'. – Neil_UK Dec 21 '16 at 10:15
