A Vivado IP is generating an inordinate amount of Modelsim warnings which are making it difficult to assess the simulation for warnings I actually care about.
I see from the Modelsim command documentation that in order to suppress a warning I need to include the parameter -suppress and then the warning numbers. My current implementation is as follows...
vsim -voptargs=+acc \
-L work \
-L xil_defaultlib \
-L secureip \
-L simprims_ver \
-L unifast_ver \
-L unimacro_ver \
-L unisims_ver \
-L xpm \
-L fifo_generator_v13_1_1 \
-L blk_mem_gen_v8_3_3 \
work.blr_tb xil_defaultlib.glbl -l sv_sim.log -suppress 3015,3017,3722
This code snippet works but I am afraid that this will suppress warnings that are created by problems with my own rtl. Is there a way of suppressing specific warnings of an IP?
For reference the warnings are all from the Vivado MIG IP and look something like this...
# ** Warning: (vsim-3017) ../../ip/xc7k160t2ffg676-2/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/phy/mig_7series_v4_0_ddr_mc_phy_wrapper.v(1260): [TFMPC] - Too few port connections. Expected 9, found 8.
#    Time: 0 fs  Iteration: 0  Instance: /blr_tb/blr_sbk_top_i/ddr3_balor_i/u_mig_ddr3_64bit_32G/u_mig_ddr3_64bit_32G_mig/u_memc_ui_top_std/mem_intfc0/ddr_phy_top0/u_ddr_mc_phy_wrapper/gen_dqs_iobuf_HP/gen_dqs_iobuf[0]/gen_dqs_diff/u_iobuf_dqs File: C:/Xilinx/Vivado/2016.2/data/verilog/src/unisims/IOBUFDS_DIFF_OUT_DCIEN.v
The MIG is compiled with the following command...
vlog  -work xil_defaultlib -incr \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/mig_ddr3_64bit_32G.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/mig_ddr3_64bit_32G_mig_sim.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/clocking/*.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/controller/*.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/ecc/*.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/ip_top/*.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/phy/*.v" \
"$SBK_IP_DIR/mig_ddr3_64bit_32G/mig_ddr3_64bit_32G/user_design/rtl/ui/*.v"
Marmstrong
  • 323
I don't think you can suppress one warning without suppressing all warning of that number.
You can edit your local modelsim.ini file
look for
[msg_system]
; Change a message severity or suppress a message.
; The format is: <msg directive> = <msg number>[,<msg number>...]
; Examples:
;   note = 3009
;   warning = 3033
;   error = 3010,3016
;   fatal = 3016,3033
;   suppress = 3009,3016,3043
; The command verror <msg number> can be used to get the complete
; description of a message.
suppress = 2083,2070
PKo
  • 163
