If the ripple-carry adder is fewer gates and satisfies timing constraints, why should the synthesizer not prefer it? In many cases, the most efficient way to generate a carry chain is to use a mixture of ripple-carry and lookahead units. For example, if one is implementing a 32-bit adder with a 16-gate-delay timing budget, rendering it as two eleven-bit sections and a ten-bit section may require fewer gates than the fastest possible arrangement while still meeting the timing requirements.
I'd suggest figuring out how to play with timing constraints; I would guess you'd find that independent of whether you design in a ripple-carry or carry-lookahead adder, the mix of ripple- and lookahead-carry generated by the compiler would vary with the constraints specified. If you wish to maintain a particular arrangement of carry logic, you can explicitly tell the compiler that you want certain signals generated (since this is a fictional design anyway, routing them to I/O pins might be a good way to do that). I suppose a compiler might still decide to ignore the P and G signals even if it was forced to generate them, but hopefully it would be smart enough not to do that.
