I didn't seam to see the controller for those simple GLCDs on the list of controllers for the microchip graphics library.
Does it support such libraries, or do i have to create a custom controller to support such?
TiOLUWA
  • 783
You can build your own graphics "driver" that integrates seamlessly with the Microchip Graphics Library, for any graphics LCD you have. I was able to use the graphics library with a different type of color LCD that the library did not support by default.
The process is as follows:
  1. Download the Graphics LCD library from microchip
  2. Make a copy of an existing "driver" code file/folder (I'm not sure if I found the exact files/folders, but you get the idea)
    • see Lib\Object Layer\Configs\XXX.c and Lib\Primitive Layer\Configs\XXX.c
    • see Lib\S1D13517\
  3. Modify the code to reflect the exact protocol the LCD needs (refer to its datasheet)
    • Typically serial and parallel LCDs are supported (for parallel LCDs, the PMP / Parallel Master Port module is useful)
    • Start with the "init" function, and be able to send the commands it needs to initialise
    • After that try sending commands to set a pixel, which will be used to draw lines, curves, rectangles, etc
    • If the LCD supports accellerated primitives like lines/curves, then you can modify the driver file to directly send those. Otherwise leave the defaults (uses the set pixel function)
    • For text, you can choose font to embed in your app and the library will draw text with that font
Robin Rodricks
  • 866
