15
Both physicists developed really powerful laws which still nowadays rule the electronic behavior of circuits.
These help us every day to solve problems, calculate circuit variables… but how did engineers do it before the said laws were discovered?
If alternative laws which would not be accepted nowadays were used before this, would this mean that the research done until the discovery of the laws was wrong? Did Kirchhoff and Ohm themselves rely on wrong theories to create 'the good one'?
Adam Haun
  • 21,331
  • 50
  • 91
xvlaze
  • 273
    Very little electrical engineering took place back then. Think of the experimens with entertaining the rich with making dead frogs legs move by using external batteries/voltage piles. – winny Dec 02 '16 at 08:42
    There were no "electronics problems" back then, since the whole field didn't exist until after the basics were figured out. – PlasmaHH Dec 02 '16 at 08:47
    These 'laws' do not "rule the electronic behavior of circuits", they *describe* this behavior. – brhans Dec 02 '16 at 14:16
This is a bit like asking how Aztecs built cars without the wheel: they didn't.
There was a chain of invention by scientists in the early 1800s building off each others work. Prior to then there was only electrostatics: Benjamin Franklin rubbing insulators together and noting charged objects attract and repel. Leyden jars.
In 1800 Volta invented the battery or "pile". This allowed experiments with a constant source, rather than ephemeral electrostatic discharge. That led to Davy inventing the arc lamp, and Ohm in 1827 quantifying this electricity. Then Faraday's work on electromagnetism, allowing generators, dynamos and motors.
Engineers turning it into a "product" came later. Swan and Edison both invented the light bulb; Edison, Tesla and Westinghouse fought over distribution.
There's a little discussion of Kirchoff and Ohm here.
Kirchhoff's laws followed from applying Ohm's law but the way in which he was able to generalise the results showed great mathematical skills. At this stage Kirchhoff was unaware that Ohm's analogy between the flow of heat and the flow of electricity, which formed the accepted understanding of electrical currents at that time, led to an incorrect understanding of electrical currents. Since no heat flowed in a body at a uniform temperature, it was believed that a static current could exist in a conductor. Kirchhoff's work would, a couple of years later, lead to him to realise this error and to give a correct understanding of how the theory of electric currents and electrostatics should be combined.
Which suggests that the answer was yes - people were building off incorrect theory to some extent. In the case of Ohm, he was building off Fourier's work on heat conduction. Electrical conduction is similar but not exactly the same.
There isn't anything on quite the scale that "phlogiston" was in chemistry - a controversial popular theory that ultimately turned out to be wrong.
pjc50
  • 46,540
  • 64
  • 126
Before tubes or semiconductors were used there was no electronics science, only electric science did exist.
When Georg Simon Ohm discovered the laws of electrical resistance, he needed voltage sources with constant voltage independent of load current. He tried galvanic elements first, but their internal resistance was too high and the voltage not constant. He used thermoelements instead and the constant temperatures of ice water and boiling water. For different voltages, he used serial connections of several thermoelements. It is very remarkable that Ohm was able to find the law using such low voltages. He constructed and built the necessary current meter by himself. The input resistance of a lot of current meters used today would be much too high for such measurements. Ohm had very remarkable experimental skills in doing his reserach with thermolements only, the mean error of his measurements was less than 1 %.
JimmyB
  • 3,823
Uwe
  • 2,783
  • I'm questioning your beginning statement. Note to whomever flagged this answer: just because the answer might be wrong does not qualify it for deletion, use the voting buttons for that. – Voltage Spike Dec 02 '16 at 18:40
Kirchoff and Ohm were in the vanguard of the developing science. Their 'Laws' were the result of trying to systematise what they observed.
Once they could measure something, current by deflecting a compass needle with a coil of wire, voltage by counting how many batteries they had in series, resistance by using lengths of wire of a given cross section, they noticed that certain values were always in a constant ratio. The rest, as they say, is part of the history of science.
Neil_UK
  • 158,152
  • 173
  • 387
  • Ohm used no batteries for measurement, the voltage of the galvanic elements he tried were not constant for a precise measurement. – Uwe Dec 07 '16 at 13:29
  • I'm no historian, so I'd be grateful if you could say what he *did* use, rather than what he didn't. Wikipedia says he used the new electrochemical cell invented by Alessandro Volta, which as far as I can see from his wiki entry was a stack of copper and zinc electrodes wetted by sulphuric acid. Two plates and one separator could well be called a cell, but a stack of them is usually known as a battery. Unless you're drawing a distinction about whether the voltage was constant? Which it isn't in modern batteries (except for Weston). – Neil_UK Dec 07 '16 at 14:07
    He tried batteries first, but their voltage was not constant under load. Then he used thermoelements kept at ice water and boiling water. He varied the voltage by the number of thermoelements in series and measured only the current. It was not necessary to measure the voltage, the internal resistance of the thermoelements was much lower than the load resistance. – Uwe Dec 08 '16 at 15:39
