I was reading about induction heating circuits in a electronics textbook and saw the terms ZVS and ZCS which are abbreviation for Zero Voltage Switching and Zero Current Switching respectively. There are many academic articles about these topics, but for a novice like me these articles are very theoretical and i can't get a grasp of topic. I would be happy if someone could help me and explain the idea behind ZVS and ZCS.
Hesam Qodsi
  • 215
That's actually pretty simple:
In many situations, you need to switch a load on and off – for example, to dim a lamp.
It's often advantageous to switch something when either the current flowing is zero, or the voltage across the load is zero.
Now, if your load is a pure resistance, then the point where zero current flows is exactly the point where zero voltage happens.
But for things like inductive or capacitive loads, that's not the case – current and voltage are out of phase for these kinds of loads.
The motivation to do something like switching a load when the current is zero is that this means you don't get \$\frac{\partial\,i(t)}{\partial t}\rightarrow \infty\$ that you'd get when switching off something when a current is flowing. And because of the physical laws, having a high \$\frac{\partial\,i(t)}{\partial t}\$ in an inductor is very bad – because it will cause a voltage peak of a very high amplitude!
Marcus Müller
  • 88,280
  • 131
  • 237
Terms Zero Voltage Switchingand Zero Current Switching are very unfortunate and misleading. More appropriate terms would be Zero Voltage Turn-on and Zero Current Turnoff.
The idea is pretty obvious: for the switch itself it is advantageous to be turned on a tad before there will be current through it, and turned off when current is already ceased.
Cubrilo
  • 359
    Zero-voltage switching can be done at turn on or turn off so there's no problem with that expression but I'll agree that zero-current switching doesn't make much sense in the off to on condition. – Transistor Feb 09 '20 at 13:24
