I have a board with the LDM and UDM pins swapped. If they are tied to low, will the memory still 'work', given that data is always written to mod 4 addresses and always using all 4 bytes?
Memory is Micron MT47H32M16HR-25E.
m.Alin
  • 10,638
  • 62
  • 89
user3812
  • 410
Yes. Since the read and writes aren't dependent on those signals, you are correct. Specifically there is no requirement that the signals transition; they can stay at a static enabled
Brian Carlton
  • 13,252
  • 43
  • 64
  • Can you give a bit more explanation @brian, right now this answer is a bit closer to a comment. – Kortuk Oct 25 '12 at 13:33
