first post here.
I'm currently making a set custom sleeved/crimped cables for my computer's modular power supply, and my crimper isn't very good, so for extra security, I've soldered all the crimps, using flux so that they flow properly. They are male-and-female type connectors, and carry high current (~5A) 12V DC, as well as some slightly lower current 3.3V and 5V DC.
After soldering, I proceeded to clean them in ethanol/alcohol, however I'm pretty sure they still have a thin layer of flux in them since it's hard to clean inside the female connectors.
I've done testing with a multimeter by first inserting a male connector, then measuring resistance and diode checks from the inserted male connector to the other end of the wire, and they check out (~0.003 ohms, the same as an un-crimped wire, the resistance is probably caused by the multimeter probes anyways, I've checked the probe-to-probe resistance to be the same).
Now for my question: If my resistances check out, and Diode check passes, will I experience unstable current under high loads? (e.g 8 Wires for a 150W graphics card)
Thanks!
