I want to communicate various sensor data in a network of sensors.
I found MQTT and MQTT-SN as suitable protocols for that. The latter being better suited for sensor networks with support for sleeping devices, predefined communication, alternatives to TCP, etc. (https://stackoverflow.com/a/29083422)
However, both are payload agnostic. The message sent can be of arbitrary format and content. Is there a common format specifically for sensor data with small footprint?
I'd like to communicate a measurement value of a specified unit and dimensionality. Maybe with a specified tolerance/expected error. I could come up with a custom format and just shove it into the payload, but I do not want to reinvent the wheel and rather use existing formats if any exist. That would also ensure compatibility to other networks that use this format.
I found
an experimental proposal for an extension to XMPP which supports things like
Unit
orTimestamp
. However, the overhead of the format being XML based makes it undesirable for my application.<message from='device@example.org' to='client@example.org/amr'> <fields xmlns='urn:xmpp:iot:sensordata' seqnr='1' done='true'> <node nodeId='Device01'> <timestamp value='2013-03-07T16:24:30'> <numeric name='Temperature' momentary='true' automaticReadout='true' value='23.4' unit='°C'/> </timestamp> </node> </fields> </message>
Home Assistant, which specifies a format that also has
unit_of_measurement
andvalue_template
. But this is more about extracting data from arbitrary MQTT messages into a format of the platform instead of specifying a format for the MQTT message itself. In fact, people write extensions to use JSON in the MQTT message
Is there simply no such thing as a standard (or at least common) lightweight message format for sensor data?
