Has someone seen or used two different silkscreen colours in the same PCB? If so, can you describe the use of them or how the manufacturing process was?
Just thinking about improving the aesthetic of the PCBs.
Jesus Castane
  • 1,442
  • 26
  • It would be great to hear from one example of this. If that exists... – Jesus Castane Nov 09 '16 at 15:11
  • Worth noting that Arduino actually uses an additional *soldermask* instead of *silkscreen* for their art. It's not inexpensive, but they are trying to be distinctive vs a low end of the market that long ago went to cheap clones (they authorize cloning the design, just not the branding/art). Part of the reason they use soldermask is that it is typically a higher resolution process than silkscreen. Some of the clones that illicitly copy the art do it in silkscreen to much reduced effect. – Chris Stratton Dec 04 '20 at 19:25
There is no technical reason why it couldn't be done, though it would not fit with some production processes where boards from different customers are panelized. Often the silk screen colors offered are very limited (white or black only) so they may not be set up for what you want.
Just ask the PCB maker, and expect an additional charge and possibly longer lead time if indeed they are willing to accommodate you.
You will have to supply separate Gerbers for each of the silk screen layers, of course, and a readme file that explains what you want. Also describe the order in which the layers should be printed, if that matters. Keep in mind that the registration won't be perfect so overlapping or touching colors have to be dealt with as you would with any another printing process (and the silk screen registration is typically not great compared to regular printing). In graphic arts parlance, this is called trapping (image below from Adobe link).
In the above, a certain amount of overprinting A is deliberately caused (equal to at least the possible misalignment between silk layers) in order to avoid the background showing through around the knockout area B.
You are essentially creating color separations, so these problems exist if you have more than one color touching.
It's easy enough to silk-screen print a board yourself, but the inks used that resist common solvents can be troublesome and/or expensive in small quantities.
For fans of Ukiyo-e floating world prints, here is an example (after Hokusai's print).
And a more functional one done using OSH Park's standard colors (by a denizen of this site).
Spehro Pefhany
  • 376,485
  • 842
That is out of the ordinary process for board houses. There is no standard way to specify that, and many board houses may not even want to bother, or charge you a lot extra. The only way to find out is to talk to some board houses to see if any will do what you want and for what price, minimum quantities, etc.
Another possibility is to have the board house use normal white silkscreen as usual. If you want a different color somewhere, specify a full white region to the board house. Then paint that yourself if you have the process, affix a pre-made sticker, etc.
Olin Lathrop
  • 310,974
  • 428
  • 915
Sounds expensive, but certainly doable if you can find someone willing to do it. It would be cheaper to use one color for silkscreen, and then get creative in the soldermask layer. You could also use different patterns and crosshatches in the screen layer.
Scott Seidman
  • 29,274
  • 44
  • 109
    The metal typically shows through the solder mask to a greater or lesser degree depending on the solder mask color (most transparent color is yellow), so you have bare metal (eg. gold), solder mask over metal, silk, solder mask over laminate, or bare laminate. That's at least 5 'colors' before you even get into the patterns @Scott suggests. – Spehro Pefhany Nov 08 '16 at 19:35
Here is a synthesizer module called "rabid elephant natural gate" which appears to have a version with a PCB front panel, it has blue and white silk screen. https://images.reverb.com/image/upload/s--XiQiUdKc--/f_auto,t_supersize/v1551111869/nq2el5g1xmno4crtbe4b.jpg
user270254
    This is really an *anecdote* not an answer. While many of the existing answers were that, they used their examples as a place to generalize from. – Chris Stratton Dec 04 '20 at 19:24
