I am wondering about the Tiny85 power consumption and methods.
I cannot find answers for the following questions in the datasheet, maybe I will find it here..
The 128Khz internal watchdog clock should use less power than the 8Mhz clock [choosing 128khz will not use the 8Mhz clock, which save power].
I am assuming 8Mhz with prescaler of 64 (gives 128khz) will be waste of power, right? I can just use the 128khz internal oscillator?
Theoretically, can I use the clock prescaler even with the 128Khz clock (CLKPR register)? If yes, I can set it to /256 = 500hz clock, which should save me some more power. In the real life I cannot do it, I need ADC, which the minimum prescaler is 2, so 128Khz will give me 64kHz at max, while the range of the ADC is 50-200khz which fit well. Am I right?
Another aspect is the output PORTs. Setting all of the output ports to be input should save some more. but Should I set them to 1 or 0 (in terms of pull up resistance) to save more power?
And last thing I need to clarify - Before powering down, I am disabling ADC in order to reduce consumption. I am setting ADEN to 0 on ADCSRA.
I read about PRR register on the datasheet and I saw I can shut TIMER0, TIMER1, USI, ADC.
Will it change the power down consumption?
Will PRR ADC shut down differ than ADCSRA disabling ADC?
Thanks.
gabi
  • 343
  • I'm sorry, but this kind of annoys me every time: The unit of frequency, *Hertz*, is abbreviated **Hz**, not *hz*. The magnitude symbol for 1000, *kilo*, is abbreviated **k**, not **K**. For a million, *mega*, the abbreviation is **M**. So, 128,000 oscillations per second are **128 kHz** (there's a space between number and unit, and note the small k and the capital H in kHz), and eight million oscillations per second are **8 MHz**. – Marcus Müller Oct 31 '16 at 16:26
  • You made it **worse**!!! It's **kHz**, not **khz**! – Marcus Müller Oct 31 '16 at 16:32
  • Too many questions for one question. Maybe narrow down to a specific ask? – bigjosh Oct 31 '16 at 16:52
  • Long answer short: yes, most of the things you propose will probably save some power. Maybe a little, maybe a lot. Try it and measure :) – marcelm Oct 31 '16 at 17:01
    It is in the datasheet. Section 24.1,2,3,4 – Janka Oct 31 '16 at 23:34
  • section 24 is "Instruction Set Summary", what should I find there? – gabi Nov 01 '16 at 08:00
If you select the internal 128kHz oscillator as the clock source, the 8MHz internal oscillator should be disabled, at least according to Atmel.
Assuming the 128kHz oscillator itself (not the core running off the clock) uses less power than the 8Mhz oscillator (a pretty safe bet), then the chip should use less power when running off the 128Khz oscillator than it does running off the 8MHz oscillator divided down to 128kHz by the prescaler.
But of course all this is conjecture! If the answer is important, then this is not a hard thing to test. Program a chip with an infinite loop and then try both fuse settings and see how much power it uses in each config. If you don't have a sensitive enough current meter, you can try running the chip off a capacitor charged to a known voltage and then measure how long it takes to drop to another known voltage in each case.
bigjosh
  • 9,888
  • The original question has several subquiestions on how to decrease the power consumption. Do you have comments on them, or just the clocking part? – Nazar Oct 31 '16 at 18:22
    Do note that the 8MHz oscillator can be tuned if you need higher accuracy, whereas the 128kHz oscillator will always run at some frequency between 96 and 119kHz. – Ignacio Vazquez-Abrams Oct 31 '16 at 19:52
