Can anyone explain why the output is so distorted and weird?
Asked
Active
Viewed 174 times
1How is the op amp powered? – Leon Heller Oct 29 '16 at 16:21
What were you expecting the output to look like? – The Photon Oct 29 '16 at 16:23
You have the op-amp connected a comparator, with the (+)input as the feedback node. In other words, you are using positive feedback.
If you want a linear amplifier, then you must use the (-)input as the feedback node. Swap the (+) and (-)inputs in your circuit.
Rich S
- 420
- 2
- 6
It's pretty much what I'd expect to see for an opamp configured as a comparator with a small amount of positive feedback.
If you we're trying to create a high gain linear amplifier swap the input pins to get negative feedback and a gain of about twenty.
- 28
- 351
- 777
