How can i get 50% duty cycles?enter image description here
Vincci
    Funnily enough the linked "duplicate" doesn't have the classic answer, which is Andy's second circuit, which works very well if the output isn't heavily loaded. –  Oct 24 '16 at 09:13
  • Is there other methods to do it? can i change the resistor value or capacitor? – Vincci Oct 24 '16 at 09:20
Try this: -
R1 dictates charge time of C1 and R2 dictates the discharge time.
Or this: -
Taken from here
Alternatively put a d type flip-flop on the output to divide the frequency by two and deliver a very good 50% duty cycle.
  • Is there other methods to do it? For example by changing the resistor value or capacitor value? – Vincci Oct 24 '16 at 09:21
    You cannot ever achieve a perfect 50% duty cycle with the standard circuit because charging the capacitor is done via two resistors whilst discharge is done via one resistor so, duty can be nearly 50% to nearly 100% with the standard circuit no matter how hard you try to change any value. – Andy aka Oct 24 '16 at 09:26
