I'm a little confused on Transistors and their power dissipation vs current.
If you look at the 2N2222A datasheet. It claims the max Vce is 40 volts.
And that the Ic max current is 1A.
It also says the power dissipation is 625mW.
So, clearly it can't do BOTH 1A & 40V and stay under 625mW.
Does that mean if I want to drive it at 40 volts, then 0.625/40 = 15.6 milliamps would be the most I could put through it?
Or say at +9V you would only get 0.625/9 = ~70mAmp.
Even at 3.3V you only get like 190milliamps.
To get a full Amp out of the transistor, you have to drive it at LESS than 1V.
What am I misunderstanding. I know I see things all over the place talking about the 2n2222 getting 1 amp out of it. But shouldn't it be burning up all the time then?
Am I misunderstanding what the power dissipation spec means? I must be.
