A couple of questions: I have a camper trailer that apparently has a dead short in either the positive or ground wires between the battery and the fuse panel. Someone told me to measure the resistance of the hot wire and ground wire from the fuse panel back to the battery. He said if the wires are good the resistance will measure zero ohms. I measured the resistance in both wires and they measured zero ohms. If the wire did have a short, what happens to the ohms reading when I measure the resistance? Is there no reading on the ohm meter or does the number of ohms measured rise dramatically?
The fuse panel: When I removed all of the fuses and add them back in one fuse at a time I found one fuse in the panel that when I replace it, it causes the main fuse to blow. Yet when I measure ohms across the fuse panel from the positive terminal to the negative terminal I get a reading of zero ohms. If the fuse panel is bad why would I get a reading of zero ohms?
