In datasheet for MOSFET driver ZXGD3003E6TA is following typical application circuit:
What should be the value of circled resistor? I did not find any reference in documentation.
Datasheet link: http://www.mouser.com/ds/2/115/ZXGD3003E6-77316.pdf
Consider your input, if you have a microcontroller driving that pin the resistor must be high enough so that MCU can drive current thru that resistor. It also must be low enough to be useful, so that gate is low when floating.
Personally i would put a 10k or similar value resistor there.
Basically here is longer answer to the guestion:
Calculating the pulldown resistance for a given MOSFET's gate
