KiCad's default library footprint for C_0402 is longer than R_0402. Why? Resistor and capacitor footprints
pericynthion
  • 6,164
IPC-7351 specifies wider land patterns for chip capacitors than chip resistors, because capacitors are usually taller, so the solder fillet "wants" to extend further laterally. Using the slimmer resistor footprint with a capacitor can lead to reduced assembly yield due to tombstoning.
pericynthion
  • 6,164
    check heights ... it is essential that the solder fillet be limited to 2/3rds of the overall height of the MLC termination, extended pad size allows for this target not to be exceeded ref IPC-SM-782A “Surface Mount Design and Land Pattern Standard”. – Tony Stewart EE75 Oct 12 '16 at 15:39
  • Consider also that the larger footprint allows more solder paste to be applied since solder paste stencils usually use the footprint gerber. In order to save space you might actually reduce the capacitor footprint but modify the stencil with a thicker stencil in capacitor areas to deposit an adequate amount of paste. – Adam Davis Oct 12 '16 at 18:14
  • IPC pads are not intended to be optimal, just the starting point to tune to manufacturers preferred standards for high yields based on chips, orientation , wave vs reflow, Don't blindly use 402 pads without knowing consequences. – Tony Stewart EE75 Oct 13 '16 at 03:21
