I do not really understand the difference between common mode chokes and coupled inductors. They are both 2 coils wrap around the same core but I know they have different purposes. I want to design a SEPIC converter with a coupled inductor but it requires high current ratings and inductance value around 1 mH. However, coupled inductors do not have these specs whereas common mode choke have. Is it okay to use a common mode choke as a coupled inductor in the SEPIC converter if the inductors are connected such that their flux are in the same direction? Reference document from Texas Instruments
Generally the answer is no, a choke will not have sufficient LI^2 energy storage compared with an inductor. This is one of the most critically important components in any switch-mode power supply. – MarkU Oct 12 '16 at 04:00
3"Insufficient LI^2 energy storage" isn't true, as you can tell by measuring the inductance and saturation current of various powdered iron chokes. The real issue is that chokes use core materials optimized for attenuating stray high frequency currents, and consequently have much lower quality factors (in other words higher losses) than power inductors designed for energy storage and general purpose inductors designed for e.g. analog filters. You can use any inductor type you can think of in a DC-DC converter as long as you are willing to severely compromise efficiency.. – jms Oct 12 '16 at 04:43
It depends on the core material properties , differential imbalance and THE MARGIN TO SATURATION if the dc + ac components are in each phase are unequal. Imbalance and saturation results in a large drop in inductance. In theory , there is no difference until it is measured. – Tony Stewart EE75 Oct 12 '16 at 05:06
@TonyStewart.EEsince'75 I did not understand well what you meant. Please correct me if I am wrong: If the currents through each coil are not equal in a choke the inductance will decrease whereas for a coupled inductor the drop won't be that much? Since I used a choke in the circuit from this question: http://electronics.stackexchange.com/questions/262948/why-does-my-sepic-converter-has-such-high-current-spikes, could this be the reason for the large spikes as in a SEPIC converter the average current through each inductor will be Iin and Iout which will be different except at 0.5 duty ratio. – Sonia Oct 12 '16 at 05:44
1A common mode choke is specified for working in a condition where the flux generated by the main differential current cancels out. So if you look into the specification of a common mode choke, there isn't anything that even tells you what the saturation current limit would be when operated as an (coupled) inductor as in a SEPIC converter. For example, a ??Amp common mode choke may have the core saturated at a fraction of that current when used as an inductor (for storing energy as flux). – rioraxe Oct 13 '16 at 01:07
@rioraxe I think you are right. I tried to use a choke as a coupled inductor and the converter was not working. The inductor current looked like saturation was reached even at low current. When I changed to 2 separate inductors, the converter was working perfectly. – Sonia Oct 14 '16 at 08:03
For what it's worth, common mode chokes are useful if you need to generate for example +/- 5V with modest loads. – Barleyman Oct 21 '16 at 10:05
Maybe. But the probable answer is 'not for your application', unfortunately. And furthermore, a better question might be, "Should I use a common mode choke instead of a coupled inductor?" And the answer to that question is always no.
Common mode chokes typically have two ratings, the differential mode current, and the common mode current. If you have found some massive choke the size of an obese house cat that 'has the right specs' (it has the high common mode current that you need), then sure, it will 'work'. It will certainly not be the best choice, but it will work.
If you're looking at the current ratings of common mode chokes and describing them as anything like 'high' or the unit is whole amperes, then that is the differential mode current rating. This rating is meaningless for any applications where one would use a coupled inductor. That current rating is a rating how many amperes of differential mode current can be handled. There is very little (in other words, there is current that is perfectly balanced, equal, in phase between the windings, but in opposite directions, like the power and ground return for it for example).
This current cancels its own magnetic flux, so it will only see the leakage inductance worth of inductance. In other words, the differential mode current is the maximum current only if you're not actually 'using' the inductance. It's essentially resistance limited. Because its the rating for currents that don't store energy magnetically, and keep in mind, inductance is a measure of energy stored in a magnetic field.
What is important for SEPIC, or really any circuit that uses an inductor for, well, its inductance, is that inductor's saturation current. This is the maximum current that the magnetic core can withstand before some chosen drop of inductance occurs (20-30% is frequently used as this drop). Or put a different way, saturation current is how much energy the magnetic core can store in a magnetic field before it's 'full'. When it's 'full', then the magnetic core isn't unable to store more energy, so increasing current beyond this point will quickly only store as much additional energy as an air-core, which presents as a rapid loss of inductance.
How this actually plays out is highly dependent on the core material. Ferrite of all kinds saturate like hot jello hitting a silicon carbide wall at 100mph. Going too close to the saturation point is simply not done, too risky, and the drop-off is too sudden.
Iron powder cores, or my favorite, carbonyl iron, saturate linearly, so you'll still have 40% of the inductance left even after you've gone to twice the saturation current. You will also have ridiculously high core losses using a powder core like that at any useful frequency, but it can be useful for peak currents in certain situations.
Chokes could be either core, both types get used for common mode chokes frequently. But it doesn't really matter, because there aren't common mode chokes rated for high current at 1mh. There are no chokes that meet your specifications - because you're using the differential mode current rating as if its the saturation current, and it isn't. A large 1mh choke rated for anything more than hundreds of milliamps saturation/common mode current would be extremely fat house cat sized (as mentioned earlier). 1 millihenry is a ton. You need sheer milliliters/inches^3 of magnetic core material if you want to store that much energy. No way around it.
Take this guy for example. It's already a behemoth at least for PCB-level stuff, and it has your inductance rating and no, it will not handle 16A of current before saturating. It will handle 240mA. For use as a coupled inductor, it's peak current 240mA. I wouldn't call that 'high current', but you didn't really mention what sort of currents you needed, so maybe that is enough. Probably not though.
This brings me to what is not going to be the answer to the question you asked, but the answer you need. I highly doubt you will find a cheap, mass-produced coupled inductor (or a choke that can be mis-used as one) that meets your specs. If you actually need 1mH at 10A or whatever you have in mind, then expect to have such a thing custom made, and expect it to be very expensive.
The reason there aren't any is because there is no need for coupled inductors that large and no reaon to mass produce them and get the cost down like chokes and reasonable coupled inductors. What I am trying to say is, if you think you need a 1mH high current coupled inductor, then your design is inherently flawed. The only reason I think think of that would require so much inductance is you want to convert currents that are far too high for a switching frequency far too low.
That design is wrong. There is no reason to do that. I suspect you have chosen some specific controller or driver that has a relatively low switching frequency, and want to build a inferior and impractical DC/DC conveter at extreme cost and no advantage, save for you don't have to learn how to use a chip that is actually appropriate for your end-goal. I suspect this because I've been there, we probably all have at some point. I make no judgement here, and freely admit to being guilty of it in my past. And what I know now is that if you think you need such a large inductor and at high power, then you don't know enough about switching converters to build one that high power.
Don't give up that goal, but work towards it by taking some intermediate steps and make smaller stuff. Learn your way around a bunch of topologies and controllers. Figure out how to select your own mosfets. Learn why electrolytics are just glorified resistors above 100KHz, or what happens to class II ceramic capacitors under DC bias (hint: they lose capacitance. Sometimes most of it. Fun! =P). Learn why you'll be optimizing a layout for every millimeter and how much a couple of nanohenries of parasitic inductance can cost you. Learn how to snub switch nodes' ringing voltages. Most of all, learn why a SEPIC converter is neither appropriate or needed for something high power that can have an input above or below the output. You would do much better with a 4-switch true buck-boost.
Ignoring all that, you do not even need a coupled inductor at that - you can just use two inductors. They need not be on the same core. The only thing sharing a core gets you is reduced ripple current. Or you could do the same by doubling the switching frequency, or using two phases at the current frequency. Either of these would be much easier, cheaper, effective, and doable. In fact, doubling the frequency gets you all sorts of other good stuff too, like reduced input ripple, reduced inductance needed, lower size, lower cost.
It's not 1990, we have switching elements that can have such low losses as to have the resistive losses from higher-inductance inductors, as well as core/hysteresis losses, outweigh switching losses until the hundreds of KHz. And even then, going faster can cost you a watt or two if you're doing it right. Take a look at the LT8705 or dozens of other 4 switch buck boost converters. They'll let you do everything a sepic could do but with 10µH of inductance, less EMI, more efficiency, be smaller than a deck of cards, and can be built using components that actually exist. If you're using something that switches at 52KHz or 70Khz or 100KHz, then you're about 26-27 years out of date. If you want to convert high power levels, well, we couldn't back then easily, not without it being more expensive than simply using big iron and big copper linear transformers/boat anchors. There is a reason switch mode power supplies began appearin when the did. High power switch mode power supplies were larger than linear supplies (but possibly a bit lighter) up until relatively recently. The power density you seem to be imagining was not possible with whatever chip it is you've selected. But that's ok, there are much better alternatives now.
So, I know you never asked about that.
But if I am to give you the most useful answer that goes beyond what you actually asked it is simply that when you say you need a 1mh high current coupled inductor....no. You don't.
- 27,884
- 4
- 64
- 119
Common mode chokes only have high inductance because of the accumulated flux from the differential currents, which means that if you try to use them as normal inductors, they will not have their rated inductance.
In other words, they only have high inductance for current differences between windings, but the windings themselves don't have the rated inductance.
If you take a look at the datasheet from some common mode chokes, you'll see that the inductance is rated at very small currents (common mode current), say 100 mA or so, even if the inductor itself is rated for 10 A or more.
http://www.murata.com/~/media/webrenewal/products/emc/emifil/knowhow/26to30.ashx
- 896
- 8
- 29
In principle you could use a common mode choke as the coupled inductor in a sepic or as 1::1 transformer in another circuit since all these are just two windings wound on to.a magnetic core.
However, it will have much lower current capability than you would expect by looking at the data sheet. Common mode chokes are intended to be used with near identical currents in the two windings such that the fluxes generated cancel almost perfectly.
They therefor don't need to store significant energy and can present a high inductance to any current imbalance.
- 4,780
- 20
- 32
It is tempting to use a common mode choke because they are small ,cheap and easy to find .However is is not going to be good because the current flows in the SEPIC and in its cousins CUK and ZETA make the magnetic fields add and not cancel .
- 14,235
- 2
- 27
- 65
