I'm currently working on a microcontroller(Arduino) project in which I wish to use interrupts generated by pushbuttons and timers. However, I'm not sure if I'm 'effectively' using the interrupts. Here is my following architecture approach:
Let's say I have three interrupt sources: one tied to a digital input, and two tied to internal timers. Upon a hardware interrupt flag being set, the associated ISRs will run.
I also implement a 'main loop'. This main loop is untimed in the sense that it will continuously run as fast the processor allows. Within this loop, there is a series of software flags that are checked. These software flags are set in the ISRs. This loop is demonstrated in the pseudo code below:
/* main loop */
while(1)
// Check digital input flag
if(digi_in_flag)
// do some routine
//check timer 1
if(timer1_flag)
// do something routine
//check timer 2
if(timer2_flag)
Now the reason I'm doing this is to keep the ISRs short. Essentially, my ISRs only set a software flag that is then checked in main loop. Some of these routines lead to SPI/I2C communications, so I didn't want to place those comms in an ISR.
So my question: does this make sense? Does this actually create a more efficient program? I feel like I'm still 'polling' by checking software flags. Alternatively to using interrupts, I could have written a loop that just checks a digital input (as opposed to a software flag set by an interrupt), or I could have just made a function to check time duration (i.e. curr_time - prev_time) instead of relying on a timer interrupt to set a software flag.
Any thoughts on this? Also, I'm limited to a single thread in this design.
Thanks
