13
I just carried out an experiment in my college to study the attenuation of fibre optic cable versus length and type of cable.
This experiment was carried out with an LED light source and a power meter connected at the other end.
The wavelength is set to 1300nm and the results obtained as follows:
Single Mode (1meter) = -36.14 dBm
Single Mode (10meter) = -36.12dBm
Multimode (1meter) = -35.94dBm
Multimode (10meter) = -18.48dBm
Anyone could explain to me why as the cable gets longer, the received power gets higher and also why multimode fiber optic cable has higher received power than single mode cable?
psmears
  • 678
hellojoshhhy
  • 253
    Are the cables the same for each length? Or did someone choose a higher quality one for the longer ones? – PlasmaHH Oct 05 '16 at 06:21
    There might be some problems in matching the LED light source to the cable and the cable to the power meter. Are the ends of all cables cut and polished with the same precision and quality? What about repeatability of those measurements? – Uwe Oct 05 '16 at 07:33
  • With -30 dB attenuation, we could ask if the light is still visible or not. – Marko Buršič Oct 05 '16 at 08:31
  • -30dB sounds pretty terrible. What do you mean by "wavelength set to": you chose a 1300nm LED and meter? – pjc50 Oct 05 '16 at 14:32
  • What is the precision of your measurements? A single number is not a measurement. – Dmitry Grigoryev Oct 05 '16 at 14:58
  • @PlasmaHH, if he's using different cables for the two lengths, then that's a problem in itself, even if the two cables came off the same spool of fiber. See my answer. – The Photon Oct 05 '16 at 15:23
    I'm not going to delete my answer, but do consider accepting The Photon's instead (you can change which you accept). In describing the cut back method, he does tell you how to avoid both the launch and the detect interface variability. – Neil_UK Oct 05 '16 at 15:47
    @JeffPang, what does your meter measure when you put it in a dark box with no input? – The Photon Oct 05 '16 at 16:27
  • @MarkoBuršič it's not -30dB attenuation, the measurement is dBm, which is a measurement of optical power. Very different. – J... Oct 06 '16 at 00:21
    You don't mention anything about the collimators, optics, and methods you are using to couple to the fiber. This tells me that either you don't think it is important or you have not considered this as a critical factor. Either way, you've overlooked the most critical link in the fiber chain - how to get the light into the fiber in the first place. This is by far where most loss happens. – J... Oct 06 '16 at 00:28
  • I think you should conduct the experiment again by using a LASER diode and a wave length of 1550nm because the attenuation is less at this wave length. –  Oct 05 '16 at 16:35
  • "_... because the attenuation is less at this wave length._" Surely that will make it more difficult to measure? – Transistor Oct 05 '16 at 17:52
  • @Transistor may be but you will get correct results. –  Oct 05 '16 at 18:01
  • @Ch.SivaRamKishore, the results won't be correct if your intended use of the fiber is with 1300 nm signals. – The Photon Oct 05 '16 at 20:45
This is where the measurement scientist has to go into full sceptical and investigative mode.
First thing. Fibre, as a passive material, is lossy. It absorbs power. Therefore the power arriving at the end of a length of fibre will be less than was launched. Period. No arguments. We don't do over-unity here.
So what causes your observations?
Single mode, 1m -36.14dBm, 10m -36.12dBm
How repeatable are your measurements? Break down and rebuild the connections, and measure again, several times (min 3, but 5 or 10 would be better). Only then can you see whether 0.02dBm is a significant physical effect or whether it's a lucky coincidence.
Measure 20m, and 30m. Is 0dB +/- 0.1dB a reasonable absorption level for 10m of fibre? I don't know, that's what you are measuring. You can be assured that the fibre loss in dB will be additive for longer lengths (for single mode, if there are multiple modes propagating this may not be true for the total power, but it's still true for each mode), so (once you're in single mode operation) you should be able to draw a linear graph of fibre length against dB loss. Remember, 2 points makes a very statistically poor graph.
And finally, I used the phrases 'arriving at the end' and 'the power that was launched'. The power in the fibre isn't necessarily the same as in the test gear. The interfaces will create uncertainty, they lose power. The power losses depend on axial alignment, the gap, the fibre face surface finish (so how well it was prepared). I would be completely unfazed by a measurement showing that a short length of fibre had a lower loss than just the source directly into the receiver, because it's about optical coupling efficiency.
Further to the repeatability measurements I asked you to make above, that's not just several repeat assemblings of the same components (which is measuring your variability), but also doing it again for different samples of nominally the same components (the variability of the system and whether the tools and methods you are provided with work repeatably). So make 3 or more samples of 1m fibre, and compare them.
Single mode 1m 36.14dBm, multimode 1m 35.94dBm
Again, characterise your repeatablity, before you jump to any conclusions on whether a measured difference of 0.2dB is significant.
Single and multi mode fibres might have different optical apertures, so have different coupling losses, quite independent of their transmission losses. Prepare some 'zero length' fibres, or as near zero as the apparatus allows, and measure those. And do 10m, 20m, 30m plots for both. Then you can start saying that there is a significant difference between them.
Multimode 1m -35.94, 10m -18.48dBm
No. Given your other measurements above, something's wrong. You've spilt coffee on the apparatus, or someone's adjusted something while your back was turned, for a laugh. Measure again.
So you thought making measurements and drawing conclusions was easy? No. Test any difference you see against your experimental repeatability. Vary one factor at a time. Consider all possible factors and control for them all. Remember, if a difference is real, it will persist as you make repeated measurements. If you just see something one time, is it the effect, is it you, is it something you hadn't thought of?
Neil_UK
  • 158,152
  • 173
  • 387
  • Coffee on the apparatus? Seems far fetched. I rather suspect the OP's measurements have been disturbed by [neutrino interference](https://en.wikipedia.org/wiki/Faster-than-light_neutrino_anomaly)... – leftaroundabout Oct 06 '16 at 18:31
27
The other answers have suggested some ways your experiment might have gone wrong. Let me tell you how to do a fiber attenuation measurement correctly.
The standard technique is called a cut-back measurement.
This means you set up your source feeding a long piece of fiber (say, 10 m). You then direct the output of that fiber into a large-area detector (large enough that it captures essentially all the light exiting the fiber), or into an integrating sphere (which is really the best way to capture all the output light). Measure the light output.
Now, without disturbing how the light is coupled in to the fiber, cut the fiber back to a shorter length (1 m in your case). Capture the output light the same way you did before, and measure the output power.
The reason to use this technique is that the launch efficiency is usually highly variable, particularly in benchtop measurements. You could easily add or subtract 3 or 6 dB (or much more, for single-mode fiber) just by misaligning the fiber to the light source by a fraction of a degree or a few microns of position. This is likely one source of error in your experiment, although you didn't describe how or when you disconnected and reconnected the source.
Another issue to watch out for is cladding modes. This is light that is coupled in to the cladding and may propagate for a few meters, but will experience higher attenuation than light in the desired modes. To avoid measuring cladding mode effects, it would be better to use longer fiber lengths for your measurement. For example, start with 100 m of fiber, and cut it back to 90 m to do the attenuation measurement.
Edit: One more issue. If you are measuring such short lengths, you'll need to be sure your light source is incredibly stable. Probably first measure the light source every second for a few hours to make sure its output power doesn't vary by more than a small fraction of the attenuation you expect from your fiber.
The Photon
  • 126,425
  • 159
  • 304
17
Neil_UK's answer is pretty much spot on, i.e. your measurements are broken. :-(
The first and most obvious problem is in the lengths chosen, 1m and 30m: These are both well within the edge effect ranges, i.e. the quality of the fiber end connections will dominate any actual attenuation loss.
In particular, good quality single mode fiber at 1300 nm can come very close to the theoretical minimum loss which is a small fraction of a dB per km, this is how transatlantic cables can work with just a few amplifiers along the way.
If we assume cheaper fiber in the 0.1 to 1 dB/km range, the 30m length still gives negligible loss. Please try 1-10 km!
Your single-mode measurement, taken on its own, would suggest that insertion/coupling losses dominate and that the difference is within the error margin (4th significant digit on a dB measurement isn't very significant). If someone had mislabelled a 1m singlemode fibre as multimode your results would all be consistent within some reasonable margin.
Coupling into multimode fibre is usually much more efficient - it's simply a bigger target with more room to get everything slightly misaligned and still get most of the light in.
What your experiment has mainly taught you is that work with singlemode fibre isn't trivial.
Chris H
  • 2,331
What type of fibre are you using? Single mode or multimode? If multimode, is it 62.5 um or 50um?
Inserting a signal into an incorrectly sized cable will suffer an immediate loss. Additionally, what connectors are you using to terminate the fibre? Is the transmitter and receiver designed for single or multi-mode?
Typically 850nm and 1300nm are used for multimode wavelengths while 1310nm and 1500nm optical windows are more often used for single mode.
Most high end optical receivers I've worked with tend to have a receive sensitivity to around -28, -30 dBm. Your receive levels measured seem to be noise. What does your receiver show with nothing connected to it?
Also, typically, optical patch cords are coloured as follows: Yellow - Single mode at 9um. orange, Multi-mode at 50um. Grey, multimode at 62.5 um.
On another note, fibre losses at multimode tend to be around 1.5dB per kilometer and single mode at around 0.15dB per kilometer. Measuring a few meters of fiber aren't going to tell you much.
