I'm interested in determining the dissipated power in an audio speaker using LTSpice. Clearly the speaker is simply modelled as a resistance, say 8 Ohms. LTSpice can directly display the DC power dissipation in a component, but how do I see the AC power dissipation? Is some sort of manual calculation required or can the software provide it?
1Clearly, modeling a speaker as a resistance is far from any real world speaker. [Have a look here](http://electronics.stackexchange.com/questions/83829/where-can-i-find-specific-examples-of-parameters-for-a-loudspeaker-circuit-model) – Arsenal Sep 28 '16 at 06:07
If you're referring to what the status bar displays when hovering over an element, or what an .op
label might show, those are readings from t=0
, the very beginning of the simulation, where the operation point is calculated. Even for DC circuits it may change due to transients in charging capacitors, etc.
LTspice provides a way to display the power dissipated in any element by pressing ALT
and then RightClick
on it. This will plot the instantaneous value, which can then be further calculated with CTRL+Click
on the waveform's title (in the waveform viewer).
Of course, for more math, one can always add external circutry that calculates this automatically. For example, you could make use of this example on how to average the AC power over a cycle, thus displaying a quasi-instantaneous average dissipated power (with a cycle delay).
- 21,167
- 1
- 20
- 40
