I was just learning about the port configurations of the GPIO pins. I came across the open drain configuration, and I was bit confused. I could not understand this properly. When this should be enabled or disabled? Should this be always enabled when the port is configured for output while transmitting?
pipe
  • 13,748
  • 42
  • 72
xyz101
  • 303
  • It sounds to me that you have a particular use case in mind, that you failed to specify. What do you mean by "transmitting"? – pipe Sep 24 '16 at 04:54
The simplified view of a digital "output" is simply two transistors, one connected to the ground, one connected to the circuit input-output power supply (Vio).
When and output is configured in "push-pull" mode, outputting a '0' connects the output pin to the ground, a '1' connects it to Vio. In "open drain" mode, the "higher" transistor is always disabled: '0' still connects the output pin to the ground, but outputting a '1' does not connect the pin to Vio, and it's left "floating".
Configuring a pin as push-pull or open drain is a choice you make during a circuit design, depending on what you want to achieve.
Sylvain
  • 809
