I'm trying to implement simple behavioural model of LMx34 devices. Circuit below tends to have negative resistance if supplied voltage drops below current source drop. How to avoid this? I prefer pure B-source solution for some reason.
Asked
Active
Viewed 349 times
You might want to specify which version of ltspice you use, since the new one might have some not yet widely known differences (in case someone tries to replicate and fails to do so) – PlasmaHH Sep 19 '16 at 13:42
I use LTspice IV for mac – e_asphyx Sep 19 '16 at 13:48
Have you tried an IF(...) statement in your B-source? – Matthew Sep 19 '16 at 21:13
I get an "timestamp too small" error. – e_asphyx Sep 20 '16 at 12:20
If the original doesn't show a negative resistance and this one does, then it's, most probably, a glitch in the implementation. Where, I couldn't tell, but this much logic I can afford... – a concerned citizen Sep 22 '16 at 14:47
