I'm trying to build an oscillator circuit for driving several IR LEDs at 38 kHz 50% duty cycle. The circuit layout I used is shown below.(Source link: http://www.electronics-tutorials.ws/waveforms/555_oscillator.html ) (Pin 7 is not connected to anywhere and I didn't use the resistor R1 in my case) Actually a really accurate duty cycle was not so important to me it could have a value +-10%. But I wanted a frequency which should be as close as possible to 38 kHz. In addition to this circuit my layout has a mosfet on its output for driving the LEDs.
50% duty cycle astable circuit
From the same web site I used this formula to calculate the resistor R2 and capacitor C1 values:
50% duty cycle frequency
I have used R2 value as 39.2 kOhm (1% tolerance) and C2 value as 470 pF (%1 tolerance). So according to calculation the frequency output should be 39152 Hz. However, the frequency that I read on oscilloscope is 35.3 kHz. So, actually my question is not about how to get the desired frequency. I could just change the resistor value by trial and get my 38 kHz. The real problem that annoys me, how I couldn't find any explanation about the 4 kHz frequency shift, which is almost 10% of the desired output. If you have any ideas about it, I really would be thankful.
Here are the components that I used:
  • TLC555 (digikey part no: 296-1336-1-ND )
  • 470 pF capacitor (digikey part no: 399-8082-1-ND )
  • 39.2 kOhm resistor (digikey part no: 311-39.2KCRCT-ND )
  • mosfet (digikey part no: DMG1012UW-7DICT-ND )
  • 10 nF capacitor for pin 5
And here I write down some important facts about my circuit and the things that I have already tried to solve the problem:
  1. First I am aware of the fact that 555 timers are not so accurate for timing. But the 4 kHz shift means that either the R value is over 43 kOhm or the C value is 520 pF. Both cases seems really not possible to me, since both componets have %1 tolerance. I also know that capacitor values tend to change depending on the applied voltage. But the dielectric material that my capacitor is C0G(NP0), which is claimed almost no change on voltage.
  2. I couldn't upload the pcb layout, I can try if needed. I have few vias on the line between pin 2 and pin 6, which wouldn't be a problem in my opinion.
  3. As I have mentioned above, I use an oscilloscope for measuring frequency on the output pin 3. I don't really know if oscilloscope is a reliable tool for frequency measurings. Maybe I should count the steps via a microcontroller.
  4. With a multimeter I measured the R value. It is 32.1 kOhm(within the tolerance range as I expected). The copper traces on the RC line are also not over few ohms. So it seems like the problem is not with the R value. But I don't also know if measuring impedance on the circuit with a multimeter is reliable or not.
  5. I couldn't figure out if the output mosfet has an effect on the frequency. I took out the mosfet and didn't see any difference.
  6. I tried another TLC555, the result was the same.
  7. When I looked at the datasheet of TLC555(TI) ( http://www.sophphx.caltech.edu/Physics_5/Data_sheets/tlc555.pdf )(page 10) I found out some properties that could delay the on off time of the output, which could reduce the frequency. I couldn't use those calculations since my setup isn't like datasheet's standard astable suggestion. So I built the circuit according to that setup on datasheet. I used 10 Kohm for Ra, 39 Kohm for Rb and the same capacitor(470 pF). According to calculations output frequency should have been near 35 kHz but the result was 31 kHz. The same 4 kHz frequency shift!
packt
  • 349
  • Did you build it on a breadboard adding maybe 10pF to the 470pF capacitor due to all the stray capacitance of the rows of contacts and long jumper wires all over the place? – Audioguru May 15 '21 at 23:54
  • Your problem is measuring by two device multimeter and osc.you shoud measure resistors value by oscilloscope Thats it – Mohammad May 15 '21 at 22:21
You should have a bypass capacitor across the supply terminals, close to the TLC555. Something like 10uF electrolytic in parallel with 1uF ceramic.
Bypassing the CONT pin as you have done may have more effect on the frequency if the supply rails are not adequately bypassed.
You might also want to put a resistor in series with the MOSFET gate to limit the current, and to use a MOSFET that has low gate charge (don't use a huge MOSFET if you don't need to).
Changes in the supply voltage during the cycle when the LEDs are on will affect the frequency so it would be better if the TLC555 was supplied with a separate regulated supply, or at least an RC.
Many of these effects can be reduced if you hang a flip-flop or two on the output and run the oscillator at 2x or 4x. You'll also get much closer to 50% duty cycle.
Unlike the bipolar 555, the TLC555 will give very close to 50% duty cycle with the configuration you are using, but the supply voltage has to remain very steady and the output reasonably lightly loaded.
Spehro Pefhany
  • 376,485
  • 842
  • I actually mentioned that I took out the mosfet and the result didn't change. So it isn't about LED currents or type of mosfet. I tried using bypass capacitors after you have told but it didn't help at all. It only changes about a hundred Hz or maybe less. I also tried the circuit with different type of resistors and different levels of supply voltage. No help. The only thing remained unchanged was the capacitor I used. Maybe it is all about it, but it shouldn't be actually since the manufacturer gurantees a max 1 percent of capacitance change. It doesn't make sense. – packt Sep 21 '16 at 13:54
  • Try removing the bypass on pin 5. – Spehro Pefhany Sep 21 '16 at 14:34
Your main problem is that the feedback-based 50% duty cycle configuration for the 555 does not yield an accurate frequency as the frequency winds up depending on output swing, and thus output loading. Using the shunt diode configuration instead fixes this dependency at the cost of a diode or two, and recalculating the resistor values.
ThreePhaseEel
  • 8,858
  • 26
  • 41
  • Is the shunt diode configuration you say this?: http://www.electronics-tutorials.ws/waveforms/tim58.gif?81223b . If so I didn't try but I tried the traditional no-feedback version: http://www.electronics-tutorials.ws/waveforms/tim47.gif?81223b . The result is the same, I still got the 4 kHz frequency shift. – packt Sep 21 '16 at 13:59
  • @packt -- the first one is the shunt diode configuration I'm talking about – ThreePhaseEel Sep 22 '16 at 00:32
